Thread: Help with front bulb replacement
    Dublin
    Default Help with front bulb replacement
    Hi all
    Hoping you can help me replace a blown front bulb in my '04 Vectra C. Please see image below for bulb in question:
    Sorry if these come across as really dumb questions:
    1) What's the correct term/name for this particular lamp/bulb? I see a lot references to offside, nearside etc and I'm not sure which one it is...
    2) What would you guys recommed in terms of a xenon bulb? Also, where's a good online shop to buy them from?
    3) Will the bumper have to come off in order to replace them? The manual seems to suggest you can access the bulbs from the bonnet...
    Thanks!
    Regular Member yadziyad's Avatar
    London
    you can access it but it is easier if you remove the bumper, go for osram nightbreakers or hids if you can afford them as they are the best. try ebay sorry forgot to add they are h7 bulbs both sides are the same so offside or nearside wont make diff
    Dublin
    Thanks for that. When I'm searching on ebay, am I looking for "sidelights"?
    Regular Member Stuarty's Avatar
    Aberdeenshire
    No dont remove the bumper to replace ur headlight bulb there is no need just remove the airbox for better access
    Apr 2009
    liverpool
    Smile
    That's the dipped or low beam, it is an H7. Don't take the bumper off! This is a 3 minute job.
    Open the bonnet. Take off the rubber dust cap. Dead easy. Grip the black plastic connector block between your fingers and twist it slightly, I think anti-clockwise. The bulb and holder will release from the headlamp reflector surround. Bulb pulls off. Be sure to avoid getting finger prints on the new bulbs glass, as it gets real hot. Assembly is the reverse. It is quicker to do the job than to type the instructions! On the other side you have to pull out the neck of the washer bottle, but thats dead easy too, it's designed to be moveable.
    I've not found expensive bulbs to be any brighter or longer lasting than cheap ones. A Halfords trade card gets them for peanuts.
    Get cheap ones and put spares in the boot, if you ever get stopped for a blown bulb, they are unlikely to give you a ticket if you can show you are prepared!
    ....I'm a night taxi driver, I get plenty of practise on bulbs
    Dublin
    Do you guys think these would work out ok?
    http://cgi.ebay.ie/Hid-Xenon-2x-H7-R...item3357e77cd1
    Do I need an adapter or anything?
    Regular Member david.aka.judas's Avatar
    Suffolk
    Ive just done mine, buy these and fit both sides:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    and fit these to match:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=270491864914
    the head lights should be £25 a pair...
    very nice.
    Dublin
    Thanks for all the replies, you guys are the greatest!
    I plumped for these in the end:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=220405170134
    Suffolk
    good luck......lol
    Apr 2009
    liverpool
    .......Can't see the point personally, but you should at least bung a cheap bulb in in the meantime. Asking for a pull.....
  1. Facelift front fog bulb replacement
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2011, 10:41
  2. bulb replacement
    By temprahater in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 22:29
  3. Facelift Front Fog Bulb replacement !!!
    By luckyone in forum Vectra C / Signum Troubleshooting
    Last Post: 21st January 2010, 22:27
