Thread: Indicator will not go off
    Camberley
    Arrow Indicator will not go off
    I removed my indicator stalk for cleaning (as my CC stop working) and when I replaced the stalk I put the indicator light on solid (the parking light I think)
    Well now the stupid indicator keeps blinking when ever I've got the keys in the ignition.
    If I hold down the stalk it will stop flashing, but I can't drive like this! How will i change gear, unless I just turn right all the time
    Help
    Owen
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    That would just send me round the bend
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    sorry good one
    would disconnecting the battary have any effect worth a try in books
    Camberley
    Arrow
    Quote Originally Posted by Sean-2.2Direct View Post
    sorry good one
    Yep tryed that for about 30 mins no effect. I've had the battary out now for a good 3 hours will see what that does.
    The funny thing is, even without the stalk in the car still indicats
    Feb 2007
    North west
    its a stuck solenoid in the fuse box, you can even get away with tapping it to free the contact and it might be ok. Replace to be on the safe side
    Camberley
    Arrow
    Quote Originally Posted by rob 2.2dti View Post
    Would that account for being able to cancel it by holding down the left turn indicator?
    Owen
    11 Post(s)
    If it was ok before you started tinkering, then it's logical that whatever you've done has caused the problem. Time to strip it down again and double check your work.
    Camberley
    Lightbulb
    I've just stripped the CIM down and swoped the stalk holders over and the problem transfered that mean's it's a mechanical Problem.
    Just been down to the scrappy and ripped apart a CIM and now have two new stalk holders for £2
    I hope that sorts it all. But my cruise control still doesn't work propperly
    Oh yeah I broke it by using too strong a cleaner :/
    11 Post(s)
    Quote Originally Posted by juiceoj08 View Post
    clutch pedal spring?
    Ireland
    I now have the same problem, is it a big job to dismantle the CIM?
    I looked at a few "how-to's", some say the steering wheel & airbag have to come off, sounds like a big hassle, maybe needing a tech2 to reset the airbag light??
    I don't understand how it happened, all I did was remove the stalk, cleaned the contacts, then put it back. The parking light did engage (indicator light on full - three pips, etc), but I can get that to go off, it's the damned indicator flashing all the the time that has me flummoxed.
    What sort of sensor controls the indicator on/off circuit, is it just pushed out of position, can I fix it without changing the CIM?
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. Indicator
    By bigal66 in forum Insignia car chat
    Last Post: 26th February 2010, 17:32
  3. Indicator
    By mbm_group in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2010, 22:26
  4. DPF Re-gen indicator
    By fredfox_uk in forum Engine & Drivetrain
    Last Post: 9th October 2009, 16:58
  5. Flashing AFL indicator
    By IanW in forum Vectra C / Signum Troubleshooting
    Last Post: 13th December 2008, 20:04
