Results 1 to 10 of 23
Thread: Engine temperature not rising?
    Jun 2009
    Belfast
    Default Engine temperature not rising?
    Can anyone help with a problem that has come up on my 55 plate 1.9CDTI 150?
    The engine temperature gauge has decided that it will not rise very much over the past month. It seems only to rise to about 70-75 degrees. Previously this would sit about 80-85 max. The fuel consumption has also dropped about 7mpg per 100miles .
    I drive approx 30 miles a day and it takes 20minutes for the temperature gauge to move at all.
    Any advice would be greatly appreciated.
    jilava
    I have the same problem, same engine. Definately we need to change the thermostat.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Could either be the thermostat or the temp sender, but a whole unit covers both items anyway - does your heater get hot pretty quick though..?
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Mine does the same too.
    Would this cause the car to run low on power low down?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Move to a warmer climate would be my advice.
    Colder these days (frost last night) and it takes longer to warm up and doesn't get as warm. Diesels normally take longer than petrols to warm up because they are usually heavier (more thermal inertia) and as they are more efficient less heat gets rejected to coolant and hence slower to warm up.
    100 miles is not a far enough distance to accurately measure a change in fuel economy, BUt cars use more fuel when it's cold outside.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    iv noticed a marked decrease in the needle position temp on my cdti but then again it does it every winter as the weather gets colder i can run 8 miles to work in the morning and the needle hasn't moved so nothing to worry about as long as you are still getting hot air through the vents
    North Yorkshire
    Just had exactly the same with mine.
    If you really put your foot down, the temperature would rise to above 80, but then drop back to about 75 when you eased off.
    Fitted a new thermostat, which was around £45 from Vauxhall, and temp now sits at 86 degrees.
    Its not like the old style thermostats, it comes as a complete housing, with several connections and a temperature sensor.
    If you have the CDC40 Opera, you can put it into test mode, and read the engine temp directly, so you know it is not the gauge.
    Press and hold "Settings" until you hear a beep. Then press "BC" several times until you come to coolant temp. The test mode cancels once the engine is switched off.
    Hope this helps.
    Jun 2009
    Belfast
    thanks guys.
    the temperature from the vents is the same as always but I am more concerned if it is related to the drop in consumption. I have lost about 70-80 miles per tank since this problem ocurred. This is the first time that the temp has fallen below the 75-80 mark since I bought the car three years ago and I know it is not because of the cold weather.
    Lancashire
    Trim : XP NAV
    If the thermostat has gone then the engine will run colder and use slightly more fuel, so could answer the mpg query.
    Winteringham
    how easy is it to replace the thermostat I do 100m per day 50m each way and mine only moves a little bit, did a big run the other day 300m and still did not move.
  1. Engine temperature up and down
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 7th March 2013, 21:01
  2. Engine Temperature keeps going up and down (2.0 DTi)
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 00:29
  3. Engine temperature
    By NI-2.2SRI in forum Engine & Drivetrain
    Last Post: 2nd February 2009, 11:40
  4. Engine Temperature
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2006, 22:30
  5. Engine temperature
    By 2ltrT in forum Engine & Drivetrain
    Last Post: 25th July 2005, 16:10
vauxhall vectra 2004 temperature not rising probley
vectra c 2.0 turbo engine temp
vectra c 2.0 turbo engine temp location
vectra c 3.0 temperature hand sit down al the time
vectra c temperature gauge not rising
vauxhall vectra c engine management on and no temperature
