Results 1 to 10 of 16
Thread: Guys - CDTi not starting today!!!!
    Apr 2008
    Northants
    Default Guys - CDTi not starting today!!!!
    Hi All,
    Came to start car this morning (06 plate 150 CDTi), i have an 'F' on the trip computer (indicating a generic fault i think).
    When the key is turned to the position where the glow plugs should come in, they stay off, and when all the other warning lights go out, the battery stays on, and when the key is turned to the turn over position - nothing happens and the battery light stays on.
    It is a cold morning, but never had any trouble before.
    Have tried jump starting to no avail.
    All electrics are working, headlights are nice and strong.
    Any ideas?
    Thanks in advance.
    Regular Member Stuarty's Avatar
    Aberdeenshire
    No idea mate wonder if its the glow plugs?
    If you can hear a click, then I'd say the starter motor's gone mate. battery's obviously ok, glowplugs will only come on below 5 degrees (I think) but the fact that the starter isn't engaging means there probably isn't a problem with them.
    When you turn the key to the start position, you shoul dhear a click. This is the relay for the starter - it takes current (and lots of it) directly from the battery so the key operater a small circuit with operates the relay to transfer power to the starter, and you can normally hear this...
    There's no fuse for it, for the above reasons... Should be able to bump start it if you know someone with a a tow rope...
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by Penfold101 View Post
    It was -2 this morning
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by Sean-2.2Direct View Post
    Tell me about it... brrrrrrrrrrrrrrr.
    But Penfold sounds spot on with his diagnosis.
    Apr 2008
    Northants
    Thanks for the suggestions - waiting for the recovery people to arrive, following a generous (not) upgrade offer from AA.
    asdasd
    MY car started flashing various signs..DANGER SLIPPERY ROADS FROST ICE loads of other stuff i was like wtf..
    starter motor probably..
    May 2006
    scotland
    -4.5 here. "F" means F****d or Frozen? I see "F" when doing the remap. Hope you get going, do tell us how you get on please.
    Apr 2008
    Northants
    Recovery guy just left. The ****ing car started first time as soon as he got here!!!!!
    No sign of any fault now. Although it has wamed up now outside.
    Vx want £80 to plug in and diagnose, as the fault code should still be logged somewhere.
    While the fault was present, i could hear the clicking sound of a relay trying to come in, therefore I was thinking starter motor.
    What now - temp sensor?
    Nah, possibly the starter on it's way out mate. Don't let VX touch it until you decide to go to them to get it replaced. it's possible with it being cold something may have gone inside, but was ok when it had warmed up a bit...
    There is nothing else in the system apart from that relay and a direct connection to the battery, so I'd say go for that if it happens again...
  1. 1.9 cdti {150} starting up
    By 1 hammer in forum Diesel Engine related
    Last Post: 5th October 2012, 21:34
  2. cdti 150 not starting
    By gazthebigyin in forum Engine & Drivetrain
    Last Post: 26th January 2011, 17:46
  3. 1.9 CDTI starting problem
    By dubsrus in forum Engine & Drivetrain
    Last Post: 27th April 2010, 16:02
  4. cdti 1.9 not starting
    By lee324uk in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 21:39
  5. 1.9 CDTI 120 starting problem
    By SUBJAM85 in forum Engine & Drivetrain
    Last Post: 16th October 2008, 11:03
