Just a quickie, my 06's drivers headlight had gone so it was pointing very low although the passenger side one was fine. I noticed when i start the car with the light on you usually see both lights drop and then lift up again but the drivers one isn't so guessing either the motor has gone (still turns left & right fine) or it has somehow come disengaged from the motor (this is more likely i think as i hit a bit pot hole and the headlight jumped up & down a lot!)
Anyone got any experience with these is it something i may be able to fix do you think or are all the motors sealed in the light?
FOr the moment i have manually wound up the height and i can live with that as moving house friday and cant really afford probably £300 for a new headlight
Cheers Steve
