Thread: Having Problems
    Regular Member karldower's Avatar
    Liverpool
    Default Having Problems
    Evening all,
    Two questions really;
    Clutch has been rattling for about six months when slightly depressed (thats pushed down not its mental state!) Thought nothing of it until tonight when I came across Flywheel threads!!! So my car is still under warranty (until next month) but its a peugeot extended warranty administored by car care plan, as I bought it second hand from a Perry's Peugeot dealer. Anyone had any dealings with them? and are they any good?
    Second one is, if I ring Vauxhall, will they be able to tell me what my car has had done previously under warranty, EGR etc?
    Thanks in advance.
    Karl
    Oct 2009
    bolton
    my vectra does sama ,still under warrenty never worried about it my last vec did same, i think its normal!
    Liverpool
    Quote Originally Posted by rush2112 View Post
    Until tonight I'd not even considered it, but with warranty running out I'm worried!!!!
    Oct 2009
    Teesside
    Hi mate, its your Dual Mass Flywheel (DMF), very common and very exensive (£1300 if you go to Vauxhall).
    Get it in and get it sorted as fast as you can under the Warranty
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    If it is the flywheel when you get in the car, press the clutch to biting point while car is in neutral, if its the flywheel it will start rattling. Could also be the throughout bearing.
    Get it checked m8 either way there shouldnt be noises coming from the engine when ur clutch is pressed. I have had the DMF issue for three years and if I knew what I know now I could have had vx fix it at their expense .
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Liverpool
    More News. Car Care Plan told me I could take it to any garage so I took it to a vauxhall garage. Result; they think its too quiet a rattle to indicate that the flywheel has actually given up the ghost, but its probably "6-12 months away". Hence the warranty company would probably not cover it. But they'd have to strip it to identify the specific problem. Plus, in order to determine the problem, i'd have to authorise the removal of the gearbox and if the warranty company then subsequently wouldn't cover it, i'd be liable to pay to have the gearbox re-fitted, at a cost to me of about £300! I'm banging my head against a wall!!!! Any suggestions?
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by karldower View Post
    To sum up, that's a garage telling you what the warranty company may say, not the warranty company themselves...? Speak to the warranty company directly, see what they say.
    Liverpool
    Sorry, i'd spoke to them both directly. Didn't make that clear. The warranty company told me exactly what they told the garage.
    May 2008
    Wiltshire
    warranty companies, what a waste of time. they said the same thing to me regarding an inlet manifold. Garage took it apart, warranty company said they would not pay. since the car was in bits i paid for the new one myself. 417 quid (fitted)
    Liverpool
    Quote Originally Posted by iasha View Post
    Thats why i'm tempted to leave it and just wait for it to take the s**t and die on me. Then put the money towards a non Vauxhall repair in 6 months!
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
