hi all
anyone know what or which engine oils i can use on my 2002 sri c 1.8 petrol?
could i use carlube semi synthetic or castrol etc
is it synthetic or just mineral and what grade would it be.
thanks
hi all
thanks
Hi semi synthetic 10w 40 or fully 5 w 30 . not mineral. vx do not supply that that anymore.
I used Mobil 1 0W-40 on my 1.8 Astra - expensive but still running better than new at 98,000.
Don't get hung up on part-synthetic (it's not "semi" it's anywhere from 1% to 99%) versus fully-synthetic, that's for the oil chemists.
For a 2002, Vauxhall recommends 10W-40 or 5W-30, ACEA-A3/B3. The API rating should be SL or SM as SJ is now obselete.
http://www.vauxhall.co.uk/vaux/owner...do?method=view
5W-40, 0W-40 and 0W-30 can also be used - with the benefit of reduced start-up wear which is just when most wear occurs.
Search for oilman's threads if you want much more detail.
If you look up your model here http://www.opieoils.co.uk/c-861-car-engine-oils.aspx You should find a selection of suitable oils.
Cheers
Guy
