Results 1 to 10 of 11
Thread: which engine oil
    norfolk
    Default which engine oil
    hi all
    anyone know what or which engine oils i can use on my 2002 sri c 1.8 petrol?
    could i use carlube semi synthetic or castrol etc
    is it synthetic or just mineral and what grade would it be.
    thanks
    Full Member
    Bristol
    Hi semi synthetic 10w 40 or fully 5 w 30 . not mineral. vx do not supply that that anymore.
    Quote Originally Posted by sb1uk View Post
    Yes they do, my dealership still offers the semi synthetic 10W40 or fully synthetic 5W30
    Mar 2007
    Tamworth
    I used Mobil 1 0W-40 on my 1.8 Astra - expensive but still running better than new at 98,000.
    Don't get hung up on part-synthetic (it's not "semi" it's anywhere from 1% to 99%) versus fully-synthetic, that's for the oil chemists.
    For a 2002, Vauxhall recommends 10W-40 or 5W-30, ACEA-A3/B3. The API rating should be SL or SM as SJ is now obselete.
    http://www.vauxhall.co.uk/vaux/owner...do?method=view
    5W-40, 0W-40 and 0W-30 can also be used - with the benefit of reduced start-up wear which is just when most wear occurs.
    Search for oilman's threads if you want much more detail.
    11 Post(s)
    Quote Originally Posted by Ruperts Trooper View Post
    For a 2002, Vauxhall recommends 10W-40 or 5W-30.
    The 10w/40 recommendation is for the Vec-B
    The 5w/30 recommendation is for the Vec-C
    Full Member
    Bristol
    if you read it meant to say they do not supply mineral oil anymore.
    Mar 2007
    Tamworth
    For a 2002 Vectra-C, Vauxhall recommends 5W-30, ACEA-A3/B3. The API rating should be SL or SM as SJ is now obselete.
    Couldn't find an edit button but have corrected my post here.
    11 Post(s)
    That's how I interpreted it as.
    Professional Trader oilman's Avatar
    Nov 2005
    Cornwall
    6 Post(s)
    Vehicle : Posche
    Trim : 928 S4
    Engine : 5.0
    Year : 1989
    If you look up your model here http://www.opieoils.co.uk/c-861-car-engine-oils.aspx You should find a selection of suitable oils.
    Guy
    oilmans website : www.opieoils.co.uk/
    e-mail : oilman@opieoils.co.uk
    tel : 01209 215164
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by oilman View Post
    Guy
    Nice link, i'll bookmark that when I get home.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
