Thread: Lights
    Aug 2009
    aberdeen
    Default Lights
    How do you tweek the front dipped beam on a vectra(56)plate?
    Can't see on the road.i have put in night brakers which does make a improvement.but???nae working.
    Cambridgeshire
    Get some HID's mate. They are all the rage apparently.
    I've got to wait for Christmas for mine ...
    11 Post(s)
    Open bonnet (obviously). Just above the headlights you'll see a couple of holes in the slam panel. The adjuster screw is the inner one of the two that you can see looking down at the slam panel. You'll need an allen key (can't remember what size) and the adjuster is quite coarse so don't go mad and start turning the screw like a madman. IIRC, it only took less than ½ a turn of each adjuster screw to raise them back up the same height as before, using Duncan's suggestion:-
    http://www.vectra-c.com/forum/showthread.php?t=33655
    Aug 2009
    aberdeen
    Cheers will try that.
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
