thanks spenny ill give it a go now
it wont rev because its in "limp" mode its just away to protect itself by not letting the turbo boost up, take it to a garage with diagnostics and find out what the fault is and clear the fault at the same time
im trying to do a fualt check but nothing is happening
i tried both but wont work
Check the small vacumm hoses for splits and also take the boost sensor out and clean it.More than likely it will be the vacumm hoses though.
check for a split in the turbo pipe common problem
Problem i had a while ago was the egr valve sticking. Same thing got to 3000 rpm and engine management light on. My veccy is a 2002 dti. Mine only did it on a long journey.
Hi, I have a 150 cdti 1.9, I had this problem and it was the EGR (exhaust gas re-circ valve- I think!!) I took it off, cleaned it with carb cleaner and it was fine,They get clogged up with diesel deposits, the ECU light went off shortly after.Not sure if your model is the same??
Hope it helps!
