Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: my car wont rev passed 3,000 rpm
    Regular Member toughmat's Avatar
    Home Rhondda , Work in Cwmbran
    Default my car wont rev passed 3,000 rpm
    Just drove back from work at the car had nop acceleration, power, torque sweat naff all.
    tried putting it into 5th gear and slapping into 3rd gear and nothing, it just wont rev past 3k.
    Any body have any ideas as to what it might be???
    Car is a 2.0 DTI 2004
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    Quote Originally Posted by toughmat View Post
    i could be the torque sweat pump.........................
    thanks but im looking for a serious reply
    Apr 2008
    Lincs
    sorry only for laughs and giggles
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Any Engine management light on?
    Its okay Grimo i forgive you.
    On the other note yes the managment light is on
    Nov 2007
    Ayrshire
    If light is on then a code will be stored, unfortunately with new style diesels about a hundred things could cause this fault!! No quick fix i'm afraid you need to find out the code!
    is there any quick way to find out the code rather than going to the dealership, i know on the vecs b you can read them with a paper clip lol??
    Full Member spennny's Avatar
    Blantyre
    Get in
    Press and hold both brake and accelerator pedals to the limit of their respective travels
    Turn ignition key to Position 2, ie dash lights on
    Release accelerator pedal
    Re-depress accelerator pedal to the floor
    Turn off ignition
    Turn on ignition to position 2
    The engine symbol on the dash will then begin to blink
    There will be a sequence of flashes, separated by small pauses between numbers and a longer pause between separate fault codes.
    The number of flashes needs to be counted and thus the 4 digit fault code can be determined.
    EG, if the flash count goes as such
    10 flashes
    small pause
    1 flash
    small pause
    1 flash
    small pause
    10 flashes
    Longer pause
    10 flashes
    small pause
    1 flash
    small pause
    10 flashes
    small pause
    10 flashes
    Then there are 2 fault codes recorded and they are
    0110 (ie 10,1,1,10 flash sequence)
    and
    0100 (ie 10,1,10,10 flash sequence)
    Hope this helps
    Nov 2007
    Ayrshire
    EASY!!
  1. She passed
    Last Post: 12th June 2012, 22:45
  2. Car Passed M.O.T.!!!! Yay
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 17:42
  3. It passed :D
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 20:52
  4. It passed!!!!!!
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2010, 22:44
  5. MOT passed !
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2008, 19:51
vauxhall zafira 2.0dti rev not going up
Vauxhall vectra rpm doesnt go up past 3500 cdti
vauxhall insignia wont rev
insignia only goes to 3000rpm
vectra c spanner light on wont rev up
vauxhall zafira engin light wont go over 3000 rpm
vauxhall insignia only revs to 3000 rpm in first
vectra 2.0 dti jumping rev
vectra c 3500rpm limit
why wont my insignia rev past 3000
vectra d under 3000 rpm
vectra b 20 dtl not over 3000 rpm
my diesel vectra wont rev past 3000 rpm
vauxhall signum diesel wont rev over 2 thousand
car wont rev past 3000 rpm vauxhall
rpm not going up vauxhall insignia
vauxhall insignia wont pass 3500 rpm
opel vectra c wont take rpm
eml light and wont rev past 3000rpm
vauxhall insignia 300 rpm
vauxhall insignia 2009 wont rev up over 3000 rpm
Vectra c wont rev past 3
3000 rpm
opel vectra rpm wont pass 30
vauxhall insignia wont rev past 3000rpm
