Results 1 to 10 of 21
Thread: Help Please 2!!
    SCOTLAND
    Unhappy Help Please 2!!
    Just started the car first time since the journey up from pvs and it wont rev. its stuttering and there is a very bad smell of petrol and fumes coming up by the drivers door. its booked in to the dealer tomorrow to have the bushes checked but not sure if its drivable any idea?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    You have turned it off and tried again mate?
    Check all air induction systems first mate.
    SCOTLAND
    just tried that and it started but big reek of fuel. reckon its the automatic choke over fueling it. aaargh ****** cars great when they are going but cack when they aint.
    will get the muppet show to take a look tomorrow while i am having words with the dip**** parts guy about a certain set of brake pads!!
    'Norf Yorks.
    Is it still stuttering though??
    Might be worth pulling the airfilter and checking there isn't a blockage.....
    As the famous words of Vectra-C are "Looks like it's time for the dealer for you!"
    Sorry mate
    SCOTLAND
    not stuttering the second time just smell of fuel. was totally fine on the way up the road apart from being a bit unstable at a high speed i reached but thats probably down to the tyres which are getting replaced tomorrow. but sat at steadt speed of about 75 most of he way with cruise control on. then off the motorway and along some a roads no probs at all. havent usedit as they have been resurfacing outside my drive so just left it sitting. will see what they say tomorrow. cheers for the replies mate.
    'Norf Yorks.
    The fuel could be the unburnt fuel in the cylinders mate, so might take a while to burn that off.
    Had it on a 1.3 Diesel Astra today. Started it and for some reason it idled at 500rpm. Turned it off, warmed up again and fired it. Ran fine but tad smokey for a mile. Otherwise fine.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Take it you were on very uneven surfaces at the pod, maybe you grounded it without knowing, have you checked the fuel lines under the car?
    SCOTLAND
    god mate i wouldnt know where to very dim with these things. theres nothing under the car that looks loose or any sign of leakage and the fuel guage is still showing fuel.
    Is the smell of fuel stronger under the bonnet or further back G??
    has the running improved??
    Vehicle : SRi
    Mileage : 137000
    Lines run under pressure when engine is running so will most likely leek when engine is on. It happened to me on my pug, just came loose joining the filter, a simple press and click to sort.
