Results 1 to 3 of 3
Thread: Urgent help needed egr fitting
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    Exclamation Urgent help needed egr fitting
    hi guys i have just taken off the manifold and egr to clean and fit the new egr,
    Problem is i have fitted everything but the egr, it wont go all the way in and seems to be catching about 5 mm before its flush if i push it gets stuck, tried putting the old one back on and same problem.
    What am i doing wrong any one help me out please?
    Regular Member nick_s's Avatar
    Jul 2009
    Stoke on Trent
    I found that it is easier to put the 4 10mm bolts on first, not fully tighten, then the two 13mm bolts, most of the way, then tighten the lot.
    In essence, like most things, don't tighten all bolts until all are in and partially tightened. You need the slack to maneuver everything into place.
    BTW, I did mine this morning.
    Nov 2007
    Leeds
    sorted just tightened it in...now the car runs so much better...£150 well spent!
  1. Urgent help required! Fitting electric seats
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2013, 23:46
  2. urgent help needed?
    By webber446 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 14:30
  3. Urgent Radio Fitting Question
    By robdd1 in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2008, 13:00
  4. Urgent help required - H.I.D fitting problem
    By Kev_A in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2007, 10:29
