Thread: Rear Tailgate not Opening on vectra estate
    Regular Member si_sri's Avatar
    Nov 2009
    TELFORD
    Default Rear Tailgate not Opening on vectra estate
    Hi all,
    just had a dilema with the tailgate not opening on my 56 plate estate.......read a few threads about the problem and like many others thought it was going to be the actator motor of the lock.......stripped this out, and found nothing wrong ? put it back together and still nothing ? the interior lights were still on so i figured it was the switch on the exterior itself, so I unplugged it....still no good. i then decided to lock the lock usuing a screwdriver & leaving the boot open....next I put a wire across the terminal of the unplugged switch and hey! guess what it worked
    I un bolted the switch (exterior one - 2 x nuts) & found loads of mucky grunge & water under the rubber gator that covers the switch...whilst it was loose i reconnected it to prove the theory & in doing so I can confirm that its definately the switch......Putting it back together now.....will confirm later once proven......hope this info helps people avoid having to use a dealer....or buying new motors for the lock etc.....
    Mileage : 000
    Cheers for that well worth remembering, just incase it happens to someone else.
    Jun 2006
    Kirkintilloch, Scotland
    Before I file this one away for future reference, where please is what you refer to as "the switch on the exterior" ?
    Thanks,
    Dave
    May 2007
    West Yorkshire
    Its the rubber coated micro switch that you depress to activate the release. I had the same issue on my prev estate, a relatively easy fix, hardest/most fiddly part was removing the boot trim when replacing the rubber sheath.
    Jun 2006
    I unlock my tailgate via switch in the driver's door. Is there another one or is there a difference between models. (mine's a 2004 2.2 direct elite)
    Dave
    May 2007
    West Yorkshire
    There is a button under the tailgate lip on all estates, I also have an elite, but I now have the automatic opening/closing jobby, so rarely use it, I can open/close from the key.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    is normaly the outside switch
    Nov 2009
    TELFORD
    Default just to confirm........
    yes its the outside switch under the outside lip above the number plate i am refering too..........
    just to confirm i put it back together and all is well
    the model of my car is the vectra Sri Nav estate 150...it has'nt got the remote boot opening button on the drivers door...
    Simon.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    thats the one, outside switch on the boot its self
  1. electric tailgate opening when car unlocked
    By dreams3577 in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2012, 19:17
  2. width of estate rear door opening
    By vansboy in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2010, 19:36
  3. Replacing rear light bulb in estate tailgate. How?
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 10th November 2009, 14:07
  4. Estate Tailgate not opening
    By Ewormaharg in forum Vectra C / Signum Troubleshooting
    Last Post: 18th October 2006, 19:51
  5. Facelift Vec Estate Interior Rear Tailgate Cover
    By willc01 in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2006, 22:21
tailgate on signum not opening on remote
