Thread: Air con compressor
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Default Air con compressor
    The air con pump on my 1.8 LS has seized. If I take it off to have a look at it will I be able to drive the car round as normal without it or not? Does it effect anything else?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you will need to get it de gassed first and hav ethe fluid taken out before you remove it, plus if you remove it the aux belt wont run the alternator to recharge the batt
    Engine : Z18XE
    so that's a no then! lol. anyone got a cheap air con pump going?
    Mar 2007
    Beaconsfield, Bucks
    you can get a shorter V belt and adjust the tensioner to ensure the alternator is still driven. When I had my pump done the guy suggested while I waited for the part.
  1. Air Con Compressor
    By Siggy08 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2012, 15:52
  2. air compressor
    Last Post: 18th November 2009, 07:56
  3. my new compressor :-)
    By big rich in forum The 'Off Topic' room
    Last Post: 16th April 2009, 14:22
removing air con pump vectra c www.vectra-c.com
