Thread: Drivers door not flush
    Sep 2009
    Glasgow
    Default Drivers door not flush
    Hi all, noticed my drivers door is not sitting flush when closed it's not way off but now ive noticed it ,it's annoying me, passenger side is fine, might have been like that since I bought it dont know, but any way of adjusting the door so i can get it flush.
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    All you have to do is adjust the striker on the body of the car in a bit. Simples!
    Sep 2009
    Glasgow
    where and how please.
    Nov 2007
    Ayrshire
    Well it's cold and wet outside so i'm guessing here, not going out to check, but i'm sure there will be two torx bits securing a chrome u shaped striker to the inside of the door frame. Loosen these slightly and move it in towards the seat then tighten it again. As you move it in it will make the door shut tighter in. Hope that makes sense?
    Sep 2009
    Glasgow
    yep thanks for the info i'll get that done tommorrow, right enough it is a bit chilly tonight.
    Sep 2009
    Glasgow
    sorry what size of torx bit is needed, want to adjust at work tommorrow and dont want to take my full set.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    A wee tip. Go round the striker plate with a fine felt pen, so you can the original position, it helps a lot to judge how far you are moving it. The pen marking will wipe of easily from the paint afterwards.
    Also when you undo the bolts dont undo them completely, just enough so the plate can be moved by tapping it lightly.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    t40 male torques
    Sep 2009
    Glasgow
    cheers for the info fixed it this morning before work couldn't wait. looks a lot better, sorted now.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    my passenger rear door was the same couldn't leave it
  1. Flush or No Flush(2.2Dti)
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 20:35
  2. Drivers Door
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2007, 21:41
