Thread: New car fault codes and engine management
    Regular Member lutontownfan's Avatar
    Nov 2009
    colchester
    Default New car fault codes and engine management
    Hi tomorrow i will be picking up my Vectra sri 1.9cdti auto 2006 registered. What system does this engine run on for checking diagnostics? i have always done my own fault reading on the old vec. Can i buy a good code reader that will cover this management system? can anyone recommend please.... many thanks.
    There are a few on the likes of e-bay u481 code reader iirc. But it will only read engine codes, not anything from the abs/air bags/auto gear box etc.
    Regular Member Jezzy's Avatar
    S.E
    Tech II is the system dealers use (costs a couple of grand) - but you can get code readers in Argos (RAC branded), or on ebay, some of the ebay stuff even claims to let you make some changes to the car, but to stay the right side of the law, make sure stuff you buy doesn't used unlicenced software.
    Nov 2009
    colchester
    Thanks will try that then, my old reader is very basic in that you count the eml light flashes to get the code. However it has always worked in tracing faults and i have rectified them myself by changing sensors.
    I know that the newer vauxhalls wont work with my reader.
    have a search for "pedal trick" works on some of them, not sure which
    S.E
    Works well on bicycles.
    I'll get my coat.....if I could afford one. lol
    Only seems to work on early Vectra C
    Tried on mine, other people with 2005MY, and nothing
    Quote Originally Posted by lutontownfan View Post
    It's the same connection as you had on your Vectra B, using TEC2
    However third party devices may report all the faults, some of which are not relevant
    If you do buy a third party device then you need to be aware of that
    On the plus side the EMS has two levels of fault reporting
    The first level is the "engine fault"
    The second level is "EMS fault", and both warning lights come on, however this seems to be very rare
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    The 'pedal trick' method works on our 55 reg Facelift Club Z18XE pre VVT & has identified codes
    - P1565 : a GM Code for Speed Control Position Sensor a
    while back which disappeared of its own accord after a
    week or two ..
    then - P0567 : a Generic code identified from the U480 Code Reader book
    for Cruise Control Resume Signal Malfunction
    more recently which again disapperared of its own accord
    and now - P1565 - again, which I'm leaving alone as I expect it to
    disappear of its own accord like last time, as the car
    seems to be running OK (apart from a battery issue
    which I plan to post shortly for comments).
    The U480 I bought of Ebay earlier this year recognises the CAN bus protocol on the car but showed no DTC's which mat indicate they are GHOSTS... Cheers
  1. Replies: 3
    Last Post: 23rd November 2011, 15:07
  2. Engine Fault Codes
    By spukeyyy in forum Engine & Drivetrain
    Last Post: 17th April 2011, 21:51
  3. 2006 Signum 2.2 engine fault codes! Help please :)
    By t13con in forum Engine & Drivetrain
    Last Post: 16th January 2011, 16:39
  4. Replies: 13
    Last Post: 20th May 2010, 20:09
  5. Engine Management Light, fault doesn't show on U480 scanner
    By petesaysblimey in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 16:51
vectra c engine management codes
