Thread: DMF.....??
    North East
    Default DMF.....??
    How do you know if you are having problems with the DMF. I have a read quite a few posts re this and would like to know what are the classic symtoms of the DMF failing. I have a 1.9 CDTi [150].
    Any advise welcome.
    Regular Member robk6112's Avatar
    Halifax
    Mine used to vibrate through the clutch. Also if you rev the car when staionary you can here a rattling noise
    North East
    did it vibrate through the clutch constantly or just occassionaly?
    Regular Member PAULMAC77's Avatar
    warrington
    you will hear it rattling on idle and the noise will go once you press the clutch in. also when you turn off the engine you will hear it rattle like mad then too, gettin mine done on wednesday
    When you press the clutch down half way you may hear it go quiet - engine running. If you hear a change its your dmf thats making the noise.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If you hold the clutch pedal at biting point whilst in neutraln you will hear it rattle - thats the DMF on its way out.
    Mine has been doing it for 3 years.
    Gazza4
    Ireland
    Quote Originally Posted by PAULMAC77 View Post
    Will you let us know if it makes a big difference to the way the car drives.... Mines been rattling for a year now and over the past month gears are getting harder to select(especially when cold) and its much noisier at idle and at slow traffic speeds. Ive noticed the car isnt near as smooth to drive anymore.
    DMF's are a failed technology.... Manufacturers seem to be peristing with them because they have realised it is an easy way to make money.
    We cant blame Vauxhall/Opel though.... every manufacturer is using them now.
