Results 1 to 10 of 18
Thread: exhaust reducer size
    Regular Member denzilbud's Avatar
    cambridge
    Default exhaust reducer size
    hi all managed to get hold of a standard dual exit exhaust system from a vec turbo for my 2.2,what i wanted to know is how i should have it fitted and what size reducers will i need to do away with the centre section on my car and have a straight through pipe from flexi back,or just use the y section on the end if i do this what size diameter reducers shall i get to join the y section to existing 2.2 system,manythanks in advance
    cambridge
    anyone
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    I've done the same conversion mate. Cut both pipes before the Y section, cut 2 slots in the Y section end, slide it over your 2.2 centre section with some zorst putty and just clamp it up, jobs a good un.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    is your car petrol or diesel???
    have you got the centre and rear sections???
    cambridge
    hi mate been waiting for you to pop up is the 2.2 centre a differnt diameter to the 2.0t also would you advise doing away with the centre box as the hangers are rusted through
    cambridge
    hi glynn i have th right hand box,y piece and a straight piece which must go to cat or box on the 2.0t and the cars petrol
    it should be a straight fit then fella as i had a 3.2 mid are rear boxes on my 2.0 dti and that went straight onto the front pipe
    cambridge
    nice one mate was going to get it welded up but if i can just clamp it all the better
    no worrys mate, are you doing it yourself then ?
    cambridge
    im fitting it myself but ive got a mate that can weld
  1. Exhaust reducer, wheres best
    By Angel1368 in forum Petrol Engine related
    Last Post: 2nd May 2012, 14:27
  2. what is you exhaust size?
    By Jaspa in forum Petrol Engine related
    Last Post: 25th September 2011, 01:15
  3. Silicone reducer and 90' bend
    By TimTay in forum Petrol Engine related
    Last Post: 28th December 2010, 18:53
  4. Exhaust flexi size.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2010, 21:30
  5. 2.0T Exhaust size?
    By Robward27 in forum Petrol Engine related
    Last Post: 14th March 2009, 11:39
vectra c exhaust diameter site:www.vectra-c.com
