Thread: headlight adjustment-HELP
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default headlight adjustment-HELP
    Hi all,after fitting my Hid kit I need to adjust my headlights. Problem is one of them appeard not to want to adjust...I think its come apart somehow.
    Any ideas as to how I can fix this?....if at all
    Full Member Big Sig's Avatar
    Has the adjuster come addrift from the back of the light unto inside the lamp? If it has then just put your fingers in where the bulb goes and pull it back into the ball and socket.
    It could be that, although they would be very high if thats the case.
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Cheers BIG..they are lighting up the neighbours rooflines!!
    That could well be it. I did one of mine when changing a bulb. If you push your finger in to where the bulb sits you may find the reflector bit is easilly pushed. It should clip in fairly easilly.
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I'll have a look see tomorrow when I fit the new sidelights,mtec 501's
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    BIG u the MAN!!..had to take the leveler motor out to help me clip it back.2 minute job to fix sumat thats been annoying me for 2 years!
  1. Headlight Adjustment
    By Siggy08 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2012, 19:05
  2. Headlight Adjustment
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 22:27
  3. Headlight adjustment..'how to'
    By nikroc in forum Bodywork & Interior
    Last Post: 27th November 2009, 00:11
  4. Headlight adjustment
    By Bops in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2009, 21:39
  5. headlight adjustment
    By Robbie69 in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2008, 15:54
