Results 1 to 10 of 11
Thread: My 55 plate vectra engine sounds alittle noisey then usual
    Redcar
    Default My 55 plate vectra engine sounds alittle noisey then usual
    My vectra sounds alittle noisy sometimes when at idle revs. when i hold the clutch in it sounds normal again. Is something wrong or about to brake or am i paranoid. cheers guys
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    sounds like the clutch release bearing to me?
    Redcar
    can it damage anything its done 85000 miles. how long do clutches last. cheers for advice. would it still be noisey if it was engine related with clutch dipped at idle revs. cheers
    Nov 2009
    west wales
    what sort of noise. is it a whine ?
    Redcar
    no like a rough noise but goes when clutch pressed. its not super loud or anything just worried if its engine really. it drives fine
    Apr 2009
    Lancs/Manchester
    Quote Originally Posted by rollercoaster63 View Post
    The clutch release bearing doesnt really have any effect on the performance of the clutch and its unlikely to have any effect unless its been doing it for years. I used to have a golf with a noisy clutch release bearing and it went on and on and on!
    The most simple test is to sit the car at idle in nuetral with the bonnet up and get an assistant to depress the clutch and listen under the bonnet to see if the noise stops, and starts again when the clutch is released.
    Sep 2009
    Swindon
    Sounds like a duff gearbox, and leaks from around the gearbox?
    Frenchman
    Regular Member PAULMAC77's Avatar
    warrington
    is it a diesel? if so it will be the dual mass flywheel rattling i would have thought
    warrington
    they are always going on everyones car, im gettin mine done next week
    Regular Member Stuarty's Avatar
    Aberdeenshire
  1. best vectra/signum engine to buy on a 54 plate
    By daniel1990 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2013, 15:29
  2. Replies: 25
    Last Post: 4th August 2011, 21:19
  3. noisey 2.2 dti engine
    By peadar in forum Diesel Engine related
    Last Post: 7th July 2011, 19:21
  4. sounds boring but look, bmw, num plate bulbs
    By beefycol in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2008, 10:24
  5. Advice - noisey engine
    By Robbie in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2008, 12:15
