Results 1 to 10 of 14
Thread: 57 plate Vectra 3.0CDTi rubbish cold start
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default 57 plate Vectra 3.0CDTi rubbish cold start
    Aren't the Z30DT engines produced after late 2006 supposed to have uprated SCVs ie. have good fuel pumps?
    Went to have a look at a very nice facelift Vectra Elite 3.0CDTi Auto. 72k miles on the clock.
    This was the cold start:
    http://www.youtube.com/watch?v=8xfP4wc3l1w
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    may be the suction low pressure pump has failed?
    Full Member
    Bristol
    Got a problem there. If the pump has failed it would no start at all. If scv give problems at about 3000 plus revs. I think it may have glow plug problem . Check that first.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    don't think glow plugs do that much in a modern diesel cause of the much higher fuel pressues. probably wrong though but think they just get the bores up to temp whilst runing mostly unless realy cold 0oC >
    Full Member Big Sig's Avatar
    Thats really not good, although whatever is causing it has not brought on a fault light as the glow plugs do when they fail.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I doubt a faulty glow plug would cause such a bad cold start at 13°C...
    Going there again tomorrow afternoon. I requested the dealer to tech2 the engine to see if there is a fuel pressure problem.
    If they don't fix the pump or whatever it is...I'm not touching it with a barge pole...
    I've a built in radar for rubbish V6 CDTi's lol
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    no don't blame you leaving it if not definatly fixed
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I have a similar problem (not as severe tho ) but if i turn ignition on and off a few times and let the glow plugs go out each time around the 3rd time of doing this it starts first time.
    Irmscher Insignia CDTI 130
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    bigmac that helped my old Vec 2.2DTi to start better when it was -2°C outside...but that thing started every signle time even if I started it right away the first time.
    Also...this particular Vectra 3.0CDTI had a very bad throttle response when stationary...When I pressed the Sport button () it was fine and reacted to the slightest touch.
    I'll see what the dealer has to say tomorrow.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by Celes View Post
    They said they didn't have time to check the car. He said we should come back on Monday.
    That is today's cold start:
    http://www.youtube.com/watch?v=lGoafe229JA
  1. vectra c 2.0dti cold start problem
    By Ade-c in forum Engine & Drivetrain
    Last Post: 12th February 2011, 14:35
  2. vectra c 2003 2.2 dti cold start issue
    By sjs in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2010, 14:59
  3. Just bought a '04 plate 3.0CDTI Vectra Worth Changing Timing Belt?
    By tommychimp in forum Engine & Drivetrain
    Last Post: 8th September 2010, 22:24
  4. TCM fault ? Vectra C 03 Reg cold start problems
    By Agaspa in forum Engine & Drivetrain
    Last Post: 7th May 2010, 21:41
  5. 05 plate vectra 3.0cdti loosing water
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2010, 21:17
