Thread: New alternator now funny electrics........HELP!
    Jun 2009
    Midlands
    Default New alternator now funny electrics........HELP!
    Just had a new alternator fitted.
    Got the car back today and two weird things have cropped up.
    Firstly, the display (CD70) seems to be in constatly dimmed mode, as in night time driving.
    The headlamp switch (Auto-off-side-head) seems to have a rattle like somethings broke off inside it.
    Electric windows - The windows won't automatically continue to open you have to hold your finger on it all the way down now - Is this a preset option that can be changed???)all four will open using the fob, but only the NSF window will close using the fob.
    Also, the NS headlamp bulb had popped when I picked it up - I've replaced that and it works, is this just a coincidence????
    Has something been wiped which needs to be TECH2'd back onto the system????
    I'm a little confused why this'd happen. The battery had been flat and off the car for a bit. Is this why????
    Thanx in advance,
    Si
    Nottinghamshire
    Not sure about facelft cars, but on earlier models, you could set the screen to day, night, or auto (changes between day and night with the headlights). Can you check what it's set to in the menu?
    Does it work OK on all settings and light up OK?
    The windows forget where 'up' is when you disconnect the battery. Hold the 'up' switch for each window in turn until the window is fully up and then keep it held for a couple of seconds and you will hear a clunk from inside the door. This will reset where 'up' is and on-touch operation should now work.
    This may be a coincidence - perhaps ask the garage about this and the headlight switch?
    Jun 2009
    Midlands
    Big thanks James24!!!!!
    I never knew 'leccy windows could 'forget' where they were!
    Did what you said and it worked!!!
    As for the dimmed display, yes, it was a setting that had defaulted with the battery disconnected, even tho the radio stations were still stored!!!!!
    As for the switch, it still works fine. I thought maybe an inner contact had come adrift causing a circuit to be made for the 'dimmer' function, making the screen permantly dimmed!!!!
    BUT it's all fine now!
    Big thanx once again!
    Si
    Full Member Big Sig's Avatar
    Rtfm
    Jun 2009
    Midlands
    Well I was just happy to get it back after 3 days (and 2 return visits)from the shonky auto electrician and had to get straight to work so had no time to RTFM.
    Will do next time tho
    And now know what RTFM means too! Thanx
    Thread now
  1. electrics
    By charlotte in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2012, 00:33
  2. Electrics????
    By GRANTY in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2011, 02:45
  3. Electrics Help
    By gullarm76 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2010, 20:09
  4. tow bar electrics
    By m8wos in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2010, 21:34
  5. Funny thing happened tonight on the way home !! Not Ha Ha Funny !!
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2008, 02:26
