Thread: Park pilot front parking sensor question.
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Default Park pilot front parking sensor question.
    Does anybody know or can anybody measure the size of the hole which the front parking sensor holders require in the front bumper of a Vectra facelift. The holders are the one's which are bonded onto the rear of the bumper. I'm guessing at either 23mm or 24mm, if it's 24mm happy days as I can get a hole saw however I can't find a 23mm hole saw anywhere and I just want it to look as if it was factory fitted.
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    steve
    thats so weird as when i was fitting the same type of sensor brackets to
    my rear xp skirt i had to have a 24mm but could only find a 23mm till i asked
    me m8 and he had a stepper cone cutter which gives you from 16mm-25mm
    which is better than a holesaw cutter as its pretty rough when its cutting
    and can also slip,your best getting the stepper cone cutter but theyre
    about 20-30 pound to buy but thats better than buying another bumper.
    when your ready to cut the holes and if you use the stepper cone cutter
    then do it from the back and not the front as the cutter may make a
    chamfer on the edge of the hole you cut and you dont want the chamfer on
    the outside do you,not like i did when i was cutting the holes out of the rear
    skirt dohh
    hope this info helps
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    56 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I might know where to get one for you as i looked every where for a hole saw for mine and i found a place by me thats sells loads in all different sizes
    Irmscher Insignia CDTI 130
    Hey Andy,
    Well i measured the diameter of the protruding piece at 23mm so that will make it a good fit, however if there is supposed to be a slight gap around the sensor bracket it will have to be a 24mm hole. As you say trial and error won't work here as i'll end up replacing the bumper
    Was kinda hoping somebody with some original factory fit sensors would be able to post a pic of how it should look, otherwise i'm gonna have to around the local supermarket carparks and dealers until i spot a Veccy with them fitted.
    bigmac,
    If you local supplier happens to have a 23mm hole saw and arbor for it, will you give me a shout please, will probably go with Andy's suggestion but want to keep my options open as really don't want to mess my bumper up.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If no-one's done it by the time I crawl out from under my duvet, I'll post a pic of one of mine and measure it for you.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Hope this is of help
    my vectra came with front & rear parking sensor
    the front one look diffrent to the rear one so i've put both up for you
    PS the front ones i measured at 23mm
    Cheers, that's spot on. The front ones are slightly different in appearence.
    If anybody finds a 23mm holesaw can you let me know please
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    88 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I have one, I got it from a local tool shop, its a step cutter with the maximum hole being 23mm.. I'll see if they have any more..
  1. advice needed to complete retro fit of front park pilot
    By driver9524 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2012, 10:00
  2. For Sale: front preface bumper with park pilot
    By hairy31 in forum Parts for sale
    Last Post: 11th March 2012, 20:50
  3. Park Pilot Question
    By LeeU in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2010, 10:35
  4. Front park pilot
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2010, 21:53
  5. Park Pilot Sensor Loom
    By tramman in forum Parts for sale
    Last Post: 6th December 2009, 21:17
