Thread: Lights
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Lights
    Is it possible to remove the headlight without removing the bumper?....I've just fitted HID'S and am now replacing theside lights .
    Secondly is it possible to 'fix' the beam adjuster?mine appears to do nothing and my passenger side light,on dip, now lights up the neighbours roofline!!
    Regular Member yadziyad's Avatar
    London
    you cant remove the headlight as there is a screw under the bumper for the headlight
    May 2008
    Tyneside
    I would check that the headlight motor is properly connected. There is a nylon ball and socket connection inside the light cluster. The motor is a bayonet fitting, just twist it anticlockwise and check its still linked. My lights were all over the place when I got the car and both had become detached. HTH
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    you can reomve the headlight with the bumper still on, if your car is a pre-facelift...undo the 3 wheelarch screws and pull the bumper outwards off the pop clips and pull it down a bit you will see the nut at the bottom of the headlight hth
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Thanks for the heads up..wish ida asked BEFORE I took off the bumper yesterday to install the HID kit...dohh
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
