Thread: P1109 fault code
    Regular Member Finty's Avatar
    Jan 2006
    Ireland
    Default P1109 fault code
    Car got the dreaded spanner and went into limp mode last night. Put the code reader on it and got P1109 Secondary Port Throttle System. Cleared the code and its running fine again. Question is this the swirl valve and if so is the fault likely to come back.
    Also could my local independent fix this or is it a Tech 2 dealer job.
    Edinburgh
    did you get a subcode?
    P1109
    -0F Swirl Actuator Malfunction
    -08 Swirl Actuator Supply Voltage Range/Performance
    -05 Swirl Actuator Feedback Circuit High Voltage
    -02 Swirl Actuator Feedback Circuit Low Voltage
    -29 Swirl Actuator Feedback Signal Malfunction
    -28 Swirl Actuator Feedback Signal Malfunction
    -21 Swirl Actuator Feedback Signal Range/Performance
    -54 Swirl Actuator Feedback Powerstage High Temperature
    Jan 2006
    Ireland
    Didn't notice a subcode. It just said P1109 Secondary Port Throttle System. I cleared the code to get it out of limp mode.
    Suppose i could start with getting the swirl valve cleaned. I presume my local grease monkey could do that?
    Jan 2006
    Ireland
    Another thing...since I have cleared the dtc code to get it out of limp mode are those dtc codes cleared permanently from the ecu or will a tech 2 still pick up them up?
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    Just hope it is not a inlet manifold mine was and it does really cost my swirl rod came off every time i got it cleared work perfect until it comes back trust me it always comes back. Mine was a p1109 code but it said
    Swirl Actuator Malfunction? good luck mate
    ps i did stick it back on but still came off
  1. P1109 Error Code
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 6th August 2012, 19:49
  2. 1.9 cdti 150 Fault: P1109 B SENSOR
    By SamT in forum Engine & Drivetrain
    Last Post: 22nd February 2012, 15:27
  3. Fault Code P1109
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2010, 20:53
  4. P1109 fault code after alternator replacment
    By knfruitbat in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2010, 21:05
  5. Fault Code P1109
    By SSM in forum Engine & Drivetrain
    Last Post: 22nd January 2010, 11:56
p1109-0f
insignia fault codes po380 and p1109p1109 secondary port throttle systemp1109 vectraopel vectra cproblem p 1109dtc p1109vectra p1109dtc P 1109opel vectra p1109vectra c 1109 fault codep1109 vauxhall fault codeOpel DTC P1109-05
