Results 1 to 10 of 19
Thread: o2 / lambada sensor ??? 1.8 cdx 2001
    west midlands uk
    Default o2 / lambada sensor ??? 1.8 cdx 2001
    hi. did self diagnosis on vectra 2001 cdx 1.8 and one of the faults was o2 sensor .. now am i thinking its right that i will need to change the old one for a new one..or can i simply clean the old one? can u recomend any tools that i may need and the location of the sensor.. i think its in the center of the engine bay ... down from the sparks plugs..looks similar to a spark plug is this right ? thanks for any help
    regards lester
    Birmingham
    Hey lester, IIRC, the Oxygen sensor is on the Cat? If you stand in front of the car and look down between the ending and the rad's, you should see a wire going to somewhere, im certain thats the bad boy!
    Is the lambda sensor something different?
    Bye bye Vec B
    - Hello Siggy!
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    You don't state you engine type but on a 2002 1.8 (Z18XL) the first sensor is in the exhaust manifold above the cat and the second is under the car after the cat, yes looks like a spark plug. You may need a special tool the get it out, socket with one side cut away.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    go steady, air flow meter fails causing mixture fault then the o2 sensor voltage code.
    west midlands uk
    hi thanks for all the help so far I believe the engine is the z18xe perhaps someone can help me out (vectra 2001 cdx 1.8) so am i right in thinking that i will have 2 sensors i plan on changing the one in the engine bay first ( i took a pic hope its the right thing) is this position 1 sensor ?? many thanks lester
    Jul 2006
    TENTERDEN KENT
    Yes that is the little beast and again yes there is another one after the cat under the car. The idea being that they sense the gases before and after the cat. If the gases are not within the set parameters up comes the little orange light shaped like a car on the rh side of the instument panel.
    Jul 2009
    sussex
    Quote Originally Posted by Vaux-Man-G View Post
    no the lambda sensor is often refered to as oxygen sensor or "HEGO" ( heated exhaust gas oxygen ).
    in other words it measures the oxygen levels in the exhaust.
    west midlands uk
    hi guys thanks for the help so far... so i ordered a new sensor and the tool required to take it out/in but theirs not enough room to use it properly so its more like im just using the strength in my hands.. does anyone know if the spark plug remover is the same size as the sensor as if worst comes to worst i cud cut off the top wires and use that?? unless anyone has a simple solution??.. lester
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Are you sure it is sensor 1 that you need to change?
    The second one is to measure cat performance and the first one is used for fuelling trim for the engine to maintain fuel / air mixture correctly.
    west midlands uk
    im not sure... i managed to change the sensor 1 but light is still on so next is sensor 2 i guess then if its not that then it needs a new cat ? i
  1. Lambada Sensor confusion
    By signum04 in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2012, 23:56
  2. lambada censor
    Last Post: 5th July 2010, 17:18
  3. Lambada Sensor
    By dankidd in forum Engine & Drivetrain
    Last Post: 24th January 2009, 19:12
  4. opinions please - 2.6 v6 sri 2001
    By poves in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 22:50
  5. emissions light.. 2001 vectra 2001 dti
    By sandman jim in forum Engine & Drivetrain
    Last Post: 7th January 2009, 22:34
