Results 1 to 10 of 19
Thread: Not another knocking thread....
    Cambridgeshire
    rolleyes Not another knocking thread....
    Yes unfortunately this is however, i've been trying to find the source for ages now and it's really doing my nut .
    I'll go through what I have done so far:
    - used sticky back velcro on almost ALL of the parcel shelf.
    - Wedged the rear rubber fins/blades (the ones that hold the parcel shelf down) to stop them receding into the boot liner.
    - wedged the rear seats to stop them rattling
    - taken the rear headrests out
    - taken the parcel shelf out
    - taken everything out of the boot
    - used sticky back velcro on both door pockets in the boot to stop any rattling.
    - rear anti roll bar bushes have been changed
    - rear swing arms have been changed
    I am still getting the most annoying knocking/tapping when going over uneven ground. However, I thought I had this pinned to the parcel shelf and it hardly does it at all when I remove it but it is still there on the more 'fierce' bumps in the road.
    Does anybody have any more ideas because I am fresh out and loosing my mind
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    It will be the trim starting to loosen up, mines does it and tbh the veccy is not the best put together motor m8. Ive got the knocking too
    Part of the ownership of the car.
    Gazza4
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Volume up on the CD player should sort this right out...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Was there not a recall on some Vectra's for some spot welding to be done inside of the head liner towards the back.... or have I dreamt this..?
    Sep 2009
    Audley STAFFS
    on my VEC b, I had a similar noise, took ages to find it, it was the ariel coax, when the noise starts again, get a passanger to push up on the roof lining just to see.
    North East
    Could be the lock to the boot/tailgate, thats what it was on my estate.
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by CLOMP View Post
    another knocking tapping that I had on the VEC b was the heat shield on the petrol tank not sure if it was the back box touching it but managed to stop it. the ariel coax was at low revs ,,the heat shield was at high revs, it is suprising how sound travels,, so you look in the wrong place.
    Regular Member old cruiser's Avatar
    slough
    As bizarre as it sounds, try putting some vaseline on the rubber height adjusters on the tailgate and where they meet on the body, also on the 'v' shaped catch on the tailgate and the lower one on the rear panel , then see what happens, it cured mine as it was having the same symptoms as yours.
    Cheers Pete
    Cambridgeshire
    I shall try that tonight and let you know how I get on
    Norwich
    Trim : SXi
    Engine : 2.2
    I,ve given up trying to find out what it is, I blame the kids for breaking and making whatever noise it is...its easier!
  1. Very odd knocking
    Last Post: 4th August 2012, 09:27
  2. Yet another thread about a 'knocking noise'
    By beethamwest in forum Handling & Braking
    Last Post: 30th May 2010, 10:44
  3. Knocking
    By ianuk in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 23:47
  4. still knocking
    By adfrodsham in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2009, 10:34
  5. Bring back the Krays (thread split from scam thread)
    By VauxVeteran in forum General Chat
    Last Post: 26th July 2006, 09:58
