Thread: is it possible???
    Regular Member signum03's Avatar
    worthing
    Default is it possible???
    evening all, i have a signum 3.0 v6 cdti 2003, pre face, currently i have a ccr2006 and have been offered a complete set up of a ncdc2015, question is can i install this without issues or tech 2? thanks in advance
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Yes this is correct as long as the unit is all matching eg:NCDC2013/15 and screen are together from the same car its just a case of doing some wiring to get it to work,but if its the one i think it is it will be pretty straight forward as you will have the loom
    Irmscher Insignia CDTI 130
    Full Member Big Sig's Avatar
    Would it also just need the extra sat nav ariel base?
    worthing
    i have been told its the complete set up so i would need to drop roof lining, has anyone done this before if so how complicated is it???
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If its the one i'm thinking of its all complete with loom and aerial,so its very straight forward
    On the other hand if it isnt the one there will be some wiring modification and you would need an after market navi aerial or check ebay for a OEM one and fit it under headlining into driver's kick panel
    Plymouth
    Quote Originally Posted by signum03 View Post
    Don... UYouve done this havn't you?
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Yes Dan i have
    Its very easy just remove crab handles on drivers side back/front then pull down rear headlining and unplug aerial lead and remove old aerial base,then fit new one and plug in the aerial connector you un plugged then with the lead that comes with the navi aerial feed it down from back to front of car drivers side,down front pillar into hole at side of dash,then feed it through dash to back of stereo
