Results 1 to 10 of 13
Thread: buying coilovers
    brum
    Default buying coilovers
    Hiya just about to put an order in for thease supersport coilovers as i need it low with a good ride!
    However i just want to make sure they are the correct ones .
    They are going onto a 03 2.2dti
    thanks and the pics will be up as soon as they are on
    Full Member spennny's Avatar
    Blantyre
    Got a link mate ?
    brum
    brum
    Regular Member W17GLE's Avatar
    bolton
    They will be right. I've got them on mine and they ride well. You will need to get all the tracking/cast/camber ssetup up if you are going low as it knocks it well out. A decent garage with laser setup will be able to get it to factory specs again though.
    brum
    okedoke thanks mate it will be getting set up as im changing the controll arms and cv boots aswell
    bolton
    My control arms are gettin done tommorow. You may find the drop links on the front may need doing too as mine started knocking. Its only about £20 to change both.
    brum
    yea ive had a look at them and there nearly new. Just out of interest how much are they charging you to change the arms?
    brum
    well the kit is here and was deliverd from doichland in no less than one week and they look ace!
    started fitting them tonight but you guessed it the ****ing drop link thread was minced so off to but two tomoz to finish the first one that i started and the other three corners. Oh and that stinking top nut was seized also grrrwith mucho breaker barring and general swearing/banging/vice action she was free woop!
    Ive dropped her down to see how she looks and boy its low on those 19S and it hasnt even settled yet. I cant even get a driver between the arch I think rolling and some plastic trimming may be required if i decide to keep it as low as this!
    brum
    fitted the back yesterday without the height adjusting part and it is sitting quite high, deffo not the 95mm it quoted it lowers by. ive got the front wound about two inches from the bottom and it is still higher at the back!
    Could they have gave me the wrong springs?
    Also the adjuster does not fit over the stump/fixing of the lower arm whats up with that?
  1. Best coilovers for gsi
    By GT3071R in forum General Motoring Chat
    Last Post: 16th June 2012, 21:58
  2. Fk coilovers...
    By SUBEK in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2012, 08:18
  3. springs,shocks,coilovers buying 2moro advice needed.
    By Vectra boy in forum Handling & Braking
    Last Post: 20th August 2011, 22:20
  4. coilovers
    By ants sri in forum Handling & Braking
    Last Post: 30th April 2011, 19:42
  5. Coilovers
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 22:28
