Thread: Cap/Seal combo - Gunson Eezibleed
    Wales
    Default Cap/Seal combo - Gunson Eezibleed
    Does anyone know what cap/seal combo I need for the Gunsons Eezibleed on a CDTI 1.9?
    I’ve got 2 large caps.
    1) One cap with small, quite fine serrations on the outside edge
    2) Another, ‘chunkier’ looking cap with big serrations on the outside edge
    Seals..
    a) A very thin one (aaprox 1mm)
    b) A very thick one (approx 3mm)
    c) A third seal which is only slightly thinner than the thick one (approx 2.5mm)
    Which ones did you use?
    Wales
    McBump!
    Regular Member Jezzy's Avatar
    S.E
    It's the chunky cap - assuming your car has the same brake fluid bottle as the 2.0T....
    Full Member Penfold101's Avatar
    As said, just use the one that looks the same as what's already on there mate... Or if in doubt, try them all till one fits...
    Sep 2009
    Swindon
    Make sure you test it without and fluid in first time as two of the lids look the same, but one of them will pop off as soon as you put on the pressure.
    Could end up a bit messy otherwise
    Frenchman
    Wales
    Quote Originally Posted by frenchman View Post
    Frenchman
    Exactly What I am trying to avoid!
    Think I will chance my luck with the chunky cap and No.2 seal.
    Its infutiating becuase the destructions tell you that there is a cap & seal combo suitable for ATE systems, but dont tell you which ones they actually are! Duh..
  1. Gunson Eeezibleed
    By conman in forum Handling & Braking
    Last Post: 14th December 2012, 20:05
  2. 2.0T oil leak, poss crank seal or sump seal?
    By mann3210 in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 11:11
  3. Combo
    By fattony in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 18:18
  4. Combo van
    By Jim Bob in forum The 'Off Topic' room
    Last Post: 1st April 2009, 14:29
  5. Gunson 4142 dwell angle connections - HELP
    By Ste in forum General Chat
    Last Post: 31st January 2008, 16:52
