Results 1 to 10 of 23
Thread: Quick Tyre Question
    Leicester
    Default Quick Tyre Question
    My 19" Tyres (Avon ZZ3) have 91 load rating tyres.
    The 224 45 18" Avons have 95 load rating.
    Is this better or worse? Should I be OK with them?
    Nottinghamshire
    Don't know about better or worse - a 95 is rated to carry a heavier load that a 91. Covered here - http://www.blackcircles.com/general/sidewall
    95 tyres will give a firmer ride that 91's because the sidewalls are stiffer to carry the extra load. I've just got 4 Kumho KU31's which are 95 rated and the ride is noticably firmer than on the old 91's that I had before - which is a good thing with the standard suspension on a Vectra (and doubly so with non-bucket leather seats).
    Leicester
    Thanks James! Should be softer than my 235 35 19's though!
    As Vectra/Signum suffer the usual rear tyre inner edge premature wear, I wonder if 95's will stand up to this better?
    Have a look at the 91 and 95 rated tyres, look for "Extra Load", "XL", or "Reinforced"
    Also compare the number of structure layers
    You should find that the 91 tyres are standard and have more structure layers, the 95 tyres should be XL and have fewer structure layers
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    The 91's are XL too and as for having less structured layers , not true buddy . Its the steel inside the tyre that is strengthened not the rubber
    Regular Member PAULMAC77's Avatar
    warrington
    was goin to say ive just bought kuhmo ku31's and mine are 91y xl, u sure your kuhmo's are 95?? mine are 235 35 19's thos so if yours are different size then fair enuff lol
    ayrshire scotland
    The 18's will have a higher load index due to the fact that it has a smaller tread area and the weight doesnt get spread across as much as the 19's
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Quote Originally Posted by Maverick View Post
    I have 94 xl on my Vec, my rears lasted 41k Michelin primacy 225/45/17 but it was only the fact that the inner edges had worn down to the limit that i had to replace them.
    The remaining tyre had 3.00mm left so could off got a few thousand more miles had they not worn on the inner edge.
    Nottinghamshire
    Quote Originally Posted by PAULMAC77 View Post
    My tyres are the standard 17" size - 215/50R17. They're definitely 95W - you got me a bit worried there so I checked on the Kumho website which says they are KU31 95 W. ttp://www.kumhotyre.co.uk/tyre_selector.php
    Nottinghamshire
    I don't know what the wear is like yet. The fronts have only just gone on. The rears have been on over a year and look to be wearing evenly so far as I can see.
    I don't do may miles these days though - the rears have worn just enough for 'Ecsta' that's written around the middle of the tread to have worn off.
  1. Another quick tyre question
    By Vaux-Man-G in forum General Chat
    Last Post: 10th June 2009, 02:05
  2. Quick Tyre Question.....
    By Signum_CDTI in forum Handling & Braking
    Last Post: 23rd January 2008, 23:06
  3. Quick tyre question...
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2007, 17:22
  4. A quick tyre question please!
    By Adamdavi3s in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2007, 10:08
  5. Quick tyre question ...
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2006, 17:27
