Results 1 to 10 of 20
Thread: Particle Regen (3.0 V6 CDTi)
    Regular Member _x_Phoenix_x_'s Avatar
    Nov 2009
    North West
    Default Particle Regen (3.0 V6 CDTi)
    Getting super annoyed at this. I read a directive from GM that the particle filter regens itself (to burn off the soot from time to time), when certain criteria are met, including speed, time since last regen etc.
    Anyway, when mine does it, my mpg goes from 0.2 per hour (when running idle) to 1.0 gallons per/h. This will last for 20 mins upwards (20 mins is the minimum for a regen i believe).
    However, the car stinks of burning diesel. Its 10x worse than being behind a bus, so much so that it makes me feel ill and gives me a headache. Its worse when stood, when moving it isnt as noticeable but its ****** horrible. The alternative is to kill the engine and interrupt the regen, but i dont like doing this.
    Regens are occuring every 3-4 weeks or so.
    Does anyone else experiance this type of problem? Car is a 2008 model btw.
    Full Member Big Sig's Avatar
    I fail to see a problem there, thats exactly what uts supposed to do
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Bad piece of technology tbh and is putting deisels behind petrol again. And with the advent of these EU directives and regulations they will be a compulsory part of every new deisel produced.
    They say to cut down the amount of time s the regen occurs you should drive the car hard a bit more.
    Gazza4
    Regular Member barkzz's Avatar
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    I second Gazza4 on that one, giving the diesels a bit of stick for a period when warm does it the world of good. Just remember to leave it idling for a while once you have "stretched its legs" so to speak!
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    We're looking at 2007 Z30DT's now but this DPF keeps pushing me away. Rubbish piece of "technology"
    EVERYWHERE
    I believe that the newer (EURO V) cars eat a larger percentage of their recirculated exhaust gas, and use even thinner oils in their engines and gearboxes.
    One of the drawbacks of an engine eating more of a percentage of its recirculated exhaust gas is that it tends to produce larger soot particles. For this we have our friend the DPF, and if you want to reduce emissions even further, you have to eat more exhaust gas and therefore you'll need a bigger DPF which will need to be regenerated more often, and use more fuel in the process.
    NOx g/km actual and proposed limits.
    Euro 3: 0.50
    Euro 4: 0.25
    Euro 5: 0.18
    Euro 6: 0.08
    NOx is the 'smog' inducing greenhouse gas produced when combustion temps are high. The introduction of exhaust gas into the combustion process reduces combustion temps.
    Yes, the Euro 4 V6 CDTI eats twice as much crap as the Euro 3 CDTI!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Im sure someone on here managed to by pass their DPF albeit on a 1.9 150.
    Think they cut out the DPF inside and welded it back up then they had to crimp a vacuum tube somewhere in the engine near the firewall/bulkhead or something to that effect.
    Gazza4
    Nov 2009
    North West
    Including filling the cabin with a smell like a tanker?
    EVERYWHERE
    @ Gazza4: On the V6 you would get a fault light just by thinking about doing that! LOL
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by diesel dog View Post
    thats what happened but they just cut some pipe and folded it in on itself and they cleared the fault and never had it back again.
    Gazza4
  1. regen
    By marko1966 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th September 2012, 07:36
  2. Vectra 1.9 CDTi regen - This consistent with one . . .
    By Coupe2T in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 16:42
  3. regen on 1.9 cdti 150 06 sri
    By bigcarp1953 in forum Engine & Drivetrain
    Last Post: 17th July 2011, 15:48
  4. Bad Battery Regen causes Lumpy CDTI idle ?????????
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 9th July 2011, 19:39
  5. diesel particle filter- regen confusion
    By beakster in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2010, 19:28
