Results 1 to 10 of 28
Thread: Just Read Fault Codes Help! 3.0 CDTi
    Regular Member m300raj's Avatar
    Nov 2009
    Hampshire
    Default Just Read Fault Codes Help! 3.0 CDTi
    Hi all i have just read the fault codes of my 3.0 CDTi Estate
    and they are as follows
    Total number of fault codes: 13
    P0105 - Boost Pressure Sensor Circuit Range/Performance
    (52) - Not present
    P1625 - Main Relay Circuit Low Voltage
    (06) - Not present
    P0380 - Glow Time Relay Circuit Malfunction
    (00) - Not present
    P0650 - Malfunction Indicator (MI) Circuit Low Voltage
    (06) - Not present
    P0190 - Rail Pressure Range/Performance (Negative Deviation)
    (52) - Not present
    P0235 - Boost Pressure Low Pressure
    (12) - Not present
    P0235 - Boost Pressure High Pressure
    (11) - Not present
    P1571 - Brake Switch Circuit Malfunction
    (00) - Not present
    P1530 - A/C Relay Voltage Low
    (06) - Not present
    P0409 - Exhaust Gas Recirculation Circuit Range/Performance (Closed Valve)
    (63) - Not present
    P1235 - Guide Vane Control Rod Position Sensor Range/Performance (Stuck Closed)
    (63) - Not present
    P0615 - Starter Relay Circuit Low Voltage
    (06) - Not present
    P0615 - Starter Relay Circuit High Voltage
    (01) - Not present
    I then reset all and read the codes again, and here are the results
    Total number of fault codes: 3
    (52) - Not present
    P0381 - Glow Device Circuit High Voltage
    (05) - Present
    (06) - Not present
    any pointers in the right direction would be a great help i think the first step would be to clean the boost valve would that be right if so is there a how 2 on it as i can't see one for the 3.0 CDTi
    thanks
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The "Not present" suggests that the faults were present at some point in the past but are now gone.
    I am getting P0190 - Rail Pressure Range/Performance (Negative Deviation) on my 3.0CDTi, but that's because of the blocked SCVs
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Have you got a EML on ? if not then i would think clearing all codes and re checking
    Irmscher Insignia CDTI 130
    Sounds to me like the Engine Advance Control module was removed or disconnected, hence all the "not present" reason codes
    I agree, start the engine a few times and then recheck
    I would be quite concerned about the 0381 Glow Device High Voltage
    This suggests the glow plugs are at the end of their life or glow plug relay has failed
    As above, if the engne warning light is not coming on then carry on as normal
    Nov 2009
    Hampshire
    Hi never have had a EML on just done a reutine check to see if anything came up. the only slight cause for concern is the slight smell of diesel fumes in car and the fuel consumption is around 28.5mpg
    It's a 3.0 V6 CDTI estate, so it probably has a DPF, hence the smell
    What MY and reg?
    Nov 2009
    Hampshire
    Hi its a Y30DT 2004 54 plate
    my mates 1.9cdti does not have any fumes so find it odd and don't like it
    It doesn't have a DPF then
    That would therefore suggest either damage under the car or the pollen filter needs replacing
    I occasionally get a charcoal smell on a cold start, but certainly not any diesel smell
    Nov 2009
    Hampshire
    I have had the car on a ramp there is no visable dammage the exhaust system seems intact and in very good condition, I have just replace the pollen filter and my mate at the garage had a look under the car and suggested it may be the EGR pipe cracked the one on the front of the engine is fine but we can't see the one fully its burried deeper at the rear and thats the area where we can smell fumes but don't want to pull it all out to find nothing wrong. i am wondering if it could be the manifold? as i have read a lot about problems on here with the manifold.............
    I've never read about problems on the inlet manifold on the Y30DT, that's a new one to me
    Loads of problems on the 1,9 CDTI though
    What about trying a sniffer test?
  1. Went to get fault codes read...
    By rockafella8587 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2012, 12:05
  2. connecting to the car to read fault codes etc
    By 1ctchris in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 15:03
