Thread: Have I got this right???
    Regular Member DTGB's Avatar
    Basingstoke, Hampshire
    confused Have I got this right???
    I have recently lowered my Veccy (30-35mm)
    I took it to get a full 4 wheel alignment, and made sure all the wheels were 'in the green'. However, when i told the guy what i had done & what i wanted doing, he indicated that regardless of whether or not they aligned all the wheels, because i had lowered the suspension, getting the wheels in the green was in fact pointless?
    They set it up anyway as per a 2.2 SRI (My car is a 2.2 elegance, is that correct?)
    I run 17 inch GSI alloys too, so I guess what I am asking is, have i done the correct thing? - And if not, what's the corrective procedure?
    After all my money & hard work, the last thing i want is for it to scrub tyres & handle really badly...
    Full Member Big Sig's Avatar
    He should have got them as close as possible to the correct values.
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    I can't see why they can't do anything, sounds like a lazy person who doesn't want to work for the money.
    May 2008
    Derbyshire (south)
    It sould be ok if he's set it right, but on ocasions the camber may need setting up.
    This thread may help.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    all in green should be ok
    Regular Member W17GLE's Avatar
    bolton
    mine's lowered 65+mm and the garage managed to get mine to vauxhall spec even with out using the eibach camber bolts i bought.
    A huge thank you to all that replied above!! - I can chill a bit now!
