Results 1 to 2 of 2
Thread: was there a recall on dpf
    May 2008
    Wiltshire
    Default was there a recall on dpf
    my local garage says NO and that it will cost 83 quid for an hours labour to change ecu. Stealers EH!
    car went into local non dealer garage because the bar had come off swivel valves on inlet manifold, spanner light was on. garage has said light was for block dpf and they would blow it out with air line, take it for a run to see if it regenerates. rang vauxhall, no recall.
    is tech 2 available anywhere else? whats the best way to regen a dpf? would the inlet manifold problem be caused by a blocked dpf? can a dpf recover from being blocked?
    cheers all
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    no recals but they can do a flash program of the ecu software to update it. to get a regen get it hot then keep the speed above 30mph and revs above 2k. give it the od boot to help start the regen and take 10-20 miles
  1. BMW Recall!!!!!
    By Das in forum Comedy & Humour
    Last Post: 10th December 2012, 05:56
  2. F.P.R recall
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2012, 22:02
  3. Recall
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2011, 21:30
  4. Recall ??
    By silverhairedracer in forum Insignia car chat
    Last Post: 27th November 2009, 19:10
  5. AFL recall?
    By janc in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 17:48
