Results 1 to 10 of 14
Thread: Service cost for 1.9cdti @ 100'000 miles.
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Default Service cost for 1.9cdti @ 100'000 miles.
    As above my vectra is ready for it's 100,000 mile service witch is a full service, My local stealers want £225 to do this, What would be the differance if I went to a independant garage as times are hard as xmas soon. Do they just change all fillters and oil.car is a 1.9cdti 16v 150.Thanks...
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    shouldn't mater where you go realy as its just all the filters. + cambelt unless already done
    Jan 2008
    Irthlingborough
    cam belt was done 10.000 miles ago at stealers will have a ring around and get some other prices...
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    yes like i said all the filters is nothing special. not special tools or anything
    Jan 2008
    Irthlingborough
    so could do it myself, How hard is the fuel filter to change.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    that is a bit fidley as its easier to remove the housing and do it all in a vice. change the filter top the housing up with fuel cleaner and screw back down. then refit the whole lot. you will need some big pipe grips to get round the housing. might be beter letting some one do it but cheaper
    Regular Member barkzz's Avatar
    Im due a major service, Interim/major/interim - now major.
    Would like to get it done cheaper elsewhere, but seeing as im taking an extended warranty, im going to be doing this major one at vx.
    Think they quoted around £225, though this will obviosuly go up after christmas
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Quote Originally Posted by barkzz View Post
    doing the same, for the same reason
    It really depends on what work they are quoting for (age dependent)
    The basic service is about £150 plus VAT
    You may then need to add brake fluid renewal, etc
    Clearly they have not quoted for a cambelt change (see service book for interval), as that alone would probably be at least £200
    Feb 2007
    nr Woodbridge, Suffolk
    100k service only at Vaux main dealer nr Ipswich - £69 2 weeks ago, as its only basically an oil/ filter change. Last main service was £179. Cambelt change with new rollers (and water pump), plus brake fluid change was £337 last week.
  1. Cost of service & cambelt on 1.9cdti 150.
    By big nath in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2008, 21:12
  2. Cost of first service?
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2008, 02:58
  3. How many miles you got on your 1.9Cdti?
    By jonesy_ni in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2007, 23:35
  4. 2nd Service cost
    By MLC in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2006, 14:47
  5. Service cost
    By David2452 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2006, 17:53
vectra c 1.9 cdti main service
