Thread: Tyre Pressure
    Kent
    Default Tyre Pressure
    I could be wrong but I thought the centre screen would alert you if the tyre pressure dropped, had a flat today and nothing flashed up thats all.
    Its a 2004 2.2 DTI
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    your car wont be enables for that mate..can be fitted iirc.. but mostly on higher spec'd models...
    Regular Member nick_s's Avatar
    Jul 2009
    Stoke on Trent
    Quote Originally Posted by Dose View Post
    Is it literally something that needs to be enabled by something like Tech2?? Or do components have to be installed? I would be interested in this myself.
    Componets would have to be installed..would be quite costly i would imagine.. i will stick with checking mine everyweek
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    You will need to install the sensors...don't ask me how.
    The plugs and cables are usually there tied up out the way.
    Then it is a tech 2 job to enable the check control system..
    this will also flash up "check washer fluid level" if you haven't already got the sensor fitted...but even that is just a plug and play job I think. or you could simply short out the pins in the plug to stop it displayng that message every time you start the car or turn on the radio.!!
    Quote Originally Posted by Robsey View Post
    the sensors are easily installed (tyre fitter required) their part of the valves.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    tbh that system can be more hassle than its worth. Think you had to spec it dont think it was a standard item.
    Gazza4
  1. Tyre Pressure?
    By Knuckle in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2011, 07:21
  2. what tyre pressure??????
    By dannyjpuk in forum General Chat
    Last Post: 6th March 2010, 21:27
  3. tyre pressure
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 10:30
  4. tyre pressure for GSI
    By effone in forum Handling & Braking
    Last Post: 7th December 2008, 06:07
  5. Tyre pressure
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 18:41
