Results 1 to 10 of 16
Thread: preface full can cd70 into facelift
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    Default preface full can cd70 into facelift
    hey guys just bought a cd70 with matching paired cid from a 2004 veccy so i'm assuming preface but full canbus so im confident this will fit and work in my 07 facelift sri, will be using a gps ariel under the little centre speaker grill in the middle of the dash by the screen. but i have found something saying that the cid screens are a different shape on facelifts to prefaces so i was wondering:
    will a preface cid fit in my centre vents (facelift)?
    will i have to change to preface vents?
    will they fit?
    can i get ones that have the chrome wheels like my facelift sri?
    if not can i swap the wheels over vents to vents?
    cheers guys
    Gareth
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I think it was me who said that the facelift (06 plate onward) screens are wider.
    I know this because I fitted a 2006 face-lift screen and vents to a pre-facelift (2005) Vectra - My wife's.
    The vent surround on the facelift is also more rounded, but the air vents themselves are all the same size and are transferrable between dashes.
    I think the standard facelift screens are the same size...therefore the pre-facelift colour screen should fit into the facelift airvent surround for non colour screens.
    Just a two minute job to pop out the old screen and try your new one in it's place.
    Remove trim strip and extract 8 x T25 torx screws (4 at the bottom lugs of the surround and 4 behind the display)
    You may find fitting the aerial in the speaker hole a bit of a pig to feed through, even without the sun sensor fitted to some cars.
    If your CD70 and CID are still paired, then there is a strange side effect of popping / crackling speakers after you have turned the car / radio off...but only for the first five minutes.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    If its a CID and a CD70 that one i only think is made in widescreen.. so no need for the rest...
    Yes the vents can be moved as you like.. ive got the chrome wheels on my prefacelift
    Engine : 2.2 Direct
    Quote Originally Posted by Robsey View Post
    Then try with sunsensor and speaker fittet there.. then its impossible..
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Just to confirm that there are wide screen and standard shaped screens for the CID...
    I bought a surround for the pre-facelift CID from Vx at £40, just to find that the surround was too tall and narrow (not wide screen)...
    Part number was identical for my existing pre-facelift non-colour as the newly purchased colour screen surround. Even quoted that mine was a Pre-facelift 2005.
    They wouldn't give a refund as it was correct to TIS and that I had done it as a "special order"
    Apr 2008
    Wigan
    cheers guys
    yeah i think it was your post i read robsey was just hoping to be able to use the existing vents as i dont wanna spend any more money lol do think i got a bargain though at £205 plus £15 postage for the cd70 and screen just need the arial found that on ebay for £9ish and need a maps disk
    how did you run the ariel cable i dont have any sensors in the way was expecting a little agro lol
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    It's in the post, but the general thing was that I took my complete air vent surround out.
    Now time to curse and scuff your nuckles.
    I tied a piece of welding rod to the block and PVC taped it down to prevent too many bits sticking out to get caught up.
    Fed the black square mag-mount block up between the air pipes, you will have a narrow vertical slot between them, that is just about wide enough to pull the block through on it's side.
    Little wiggle to spin the block round to get it into the side of the speaker oriface.
    I then screwed a metal plate onto one of the speaker screw points in the centre of the dash, and mag-mounted the block to it.
    I connected up my Fakra plug to the back of the radio...of course.
    Finally I coiled up the excess wire, taped it up so that it was tidy, and tucked it in next to the mag-mount aerial.
    Then refit speaker trim panel
    And connect-up then refit the screen and airvent surround.
    Apr 2008
    Wigan
    nice one i'll have a word with the fitter at work to get some welding rod defo sounds like easier way might even pre stick plasters on the knuckles lol ahh well you aint worked on it till you've bled on it
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    any stiff wire will do!!
    It allows you to manipulate and twist the block around the nooks and crannies.
    Floppy wire or string can't do that.
    Apr 2008
    Wigan
    dont think i got any stiff wire sure a welding rod gonna be the way to go will just nab one off the volvo fitter no doubt i'll have to see him tomorrow all our wagons are pants lol
  1. changing cd30 stereo in a preface full canbus car, couple of questions
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2012, 22:11
  2. 2005 vectra 2.2 sri, preface or facelift half-can or full canbus?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2012, 13:41
  3. 2008 cd70 satnav, into a 2005 preface. plz help
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 17:42
  4. CD70 screen in a 04reg preface half canbus
    By andyman201 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 14:43
  5. cd70 colour sat nav..full kit...
    By SRI-RICH in forum Parts for sale
    Last Post: 11th February 2009, 11:20
vectra pre facelift cid vent surround part number
