Results 1 to 10 of 20
Thread: pi springs
    Full Member paul.sessions's Avatar
    leighton buzzard
    Default pi springs
    just wondering how many people on here run the 45mm drop pi spring with standard dampers and whats the ride like..
    and im thinking 30mm or 45mm... got to keep standard dampers due to cost..
    thanks paul
    koni
    eibach
    pi ?????????
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    i used to run on -45mm pi springs. looked good but the ride was a little rough. got coilovers now and its a bit more comfortable. its worth saving the extra pennies for the coilovers. £400 on ebay for hottuning coilovers
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Ride isn't too bad on my 45mm springs on standard shocks.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    ive got 45mm PI springs with standard SRI shocks and ride is fine with 18" alloys
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by bobby-tupper View Post
    As above, -45mm PI's with std (but new) SRi shocks and the ride is spot on, not choppy/harsh or anything, its as it should have been.
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    I agree..ride is better than i thought it would be
    Oct 2009
    bolton
    Default pi springs
    anyone running pi springs with 19 inch rims? if so what they like
    Regular Member the stig's Avatar
    Sep 2009
    Yorkshire
    Quote Originally Posted by rush2112 View Post
    Im on Pi,s and 19s its a good frim ride but it makes me cringe somtimes when I hit a pothole
    East Midlands
    Dropping down to 45mm springs on standard shocks bud ,is imho just a tad too low,you 'll probably end up knackering your shocks in no time,and you'll be hitting the bump stops frequently,i myself have the pi 30mm drop with billstein b4s on the rear but still have the standard shocks on the front,and it is does occasionally bottom out over large bumps ..think on.
    Regular Member Vauxhall Thru & Thru's Avatar
    May 2008
    Nottingham
    Quote Originally Posted by the stig View Post
    I'm on Pi -45mm springs, standard SRi shocks, 19'' Snowflakes. Ride is a bit 'twitchy' sometimes (hard to describe) and you can't help but cringe when you hit a pothole.
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
