Results 1 to 3 of 3
Thread: question about stereos
Hybrid View
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    Default question about stereos
    just looking at some of the different factory fitted stereos for the vectra's, CDR 2005, CD 30 & CD 70 NAV.
    does anyone know if its possible to take out a CDR 2005 or CD 30 and replace it with a CD 70 NAV? obviously that's the main unit and the screen on the dash.
    Regular Member kenp's Avatar
    Feb 2008
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    yes its possible.. the easiest is the CD30 ->CD70 its more difficult to do CDR2005 ->CD70
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Vehicle : Vectra C
    Trim : Energy
    Engine : Z19DTH
    Mileage : 150,000
    Right there is a two way answer on this...
    Regarding CC20, CD30, CDC40, CD50 and CD70...these are all interchangeable as long as you get matching screen and head-unit.
    If upgrading from CD30...
    Upgrading to CDC40 will require a Graphic Info Display (and possibly a DAB unit)
    Upgrading to CD70 Navi will require either a Mono Graphic display or a colour screen with additional nav aerial / loom and video cable.
    If upgrading from CDR2005, then you wil again need a head-unit and screen as detailed above, but you will also need to rewire / reconfigure the wiring looms.
    Also the CDR2005 uses an ISO connector and the CD30, CDC40 and CD70 all use the Quadlock type connector...I personally would use a PARROT / ISO2CAR / SOT conversion lead, and cut this to suit the ISO plug from the car and the quadlock socket on the radio.
    Try searching for the thread Fitting a CD70 to a non-canbus vehicle (It's one I did )
    Also all Vauxhall's ISO plugs from 1986 to 2004 are basically the same wiring configuration from pins 1 to 16 (speakers and power distribution and ABS speed sensor)!!
  1. difference between stereos
    By dunkymunky in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2012, 22:27
  2. stereos
    By sparky3865 in forum General Chat
    Last Post: 25th April 2012, 22:53
  3. Which of these stereos should I get?
    By danlat1415 in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2009, 17:09
  4. 2 Vauxhall stereos
    By jamesr in forum Parts for sale
    Last Post: 18th June 2007, 10:45
  5. vauxhall stereos
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2005, 23:38
