Results 1 to 3 of 3
Thread: Rear Interior Light Problem
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Default Rear Interior Light Problem
    Pulled the light out today to change a bulb and the ribbon wire has detached itself from the connector.
    Any ideas as to how this could be fixed?
    Mileage : 55000
    Can the connector be taken apart. As it might just perforate the ribbon and make a conract ( a bit like a scotch lock connector)??.
    Full Member Robsey's Avatar
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    If it detatched that easily, then it has just come undone...
    those ribbon cables aren't that flimsy...
    See if you can open up the connector, reinsert the ribbon and press it shut again...
    Once the connector is plugged back into the light, then it should be held closed by the socket.
  1. Rear Signum Light problem problem - help
  2. HELP! : Interior Light Switch re assemble problem
    By Envy in forum Troubleshooting
    Last Post: 18th September 2011, 19:54
  3. Interior Light Problem
    By Hendry in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2010, 20:13
  4. Rear Interior Light Fitted - Problem with front now....
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2009, 00:08
  5. Rear interior light
    By simonali in forum Parts for sale
    Last Post: 23rd January 2006, 00:09
vauxhall rear interior light problems
how do you change abulb on a vauxhall vectra club rear bulbs
