Results 1 to 10 of 15
Thread: How can I tell if my car has a DPF?
    Nov 2009
    North Yorks
    Default How can I tell if my car has a DPF?
    I have a 1.9cdti 120 8v 2005 on a 55 plate manual.
    How can I find out if the car has a DPF. I remember reading somewhere that you might be able to tell from the VIN.
    I've got the spanner light come up on the dash, but it should be at least another 15k to a service.
    Any ideas?
    WGAF#5
    its a modern diesel like most manufacturers they fit them to reduce emissions on diesels- it will have one - and just to make you feel better - its going to have a dual mass flywheel as well
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    DPF on Vectra Estates and Autos, (and all Signums), fitted with 1.9 or 3.0 CDTI engine. All Insignia diesels have a DPF.
    EVERYWHERE
    Quote Originally Posted by fatherandrew View Post
    Any ideas?
    The spanner/fault light (spanner with car, not oil can) means that your car has developed a fault, and needs attention by someone who can read the codes from the diagnostic socket (under the ashtray).
    The service light (spanner with oil can) means that your car needs a service.It may be that your service reminder hasn't been set correctly.
    P.S. I don't think that your car has a DPF.
    This engine and age of car won't have a DPF
    When was the car last serviced?
    Service is every 20K miles / 2 years or on indication (ECO Flex)
    The car is very unlikely to be under warranty, so you can always reset it yourself, so long as you are aware of when the next service is
    More than likely the indicator was not reset on last service
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    It is quoted in the owners handbook though, and mine's on a 54 plate!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Any ideas?
    If it is an estate it will have it, the 1.9's have never had the DPF if they are in a Hatch or Saloon.
    You can tell if it has one because every so often the regnenration light will come on telling you the DPF is cleaning itself - and does this by altering the timing of the fuel injection. But like I say if your car is not an estate it wont have it.
    Gazza4
    Gazza4
    preston
    You'll be able to tell if its got a dpf by looking under the car at the exhaust. If there are small bore fuel pipes going to the exhaust then it has one!
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Gazza4
    Ok now I am confused, I know Vx penny pinch over stupid things but why fit the DPF to the Estate but not the Hatch/Saloon models?
    Jul 2009
    lanark
    if the car has broke down, it will have the dpf.
    if the car has never broke down it wont have dpf
does the vectra c 120 have a dpf filter
how do i know if my vectra has a dpf
does 57 plate signum have dpf
does a 06 vectra have dpf
how to tell if my vectra has a dpf
does my car have a dpf fitted vauxhall vectra 1.9cdti sri 150
does my cdti have dpf
Does the vectra with 1.30 have a dpf
how can i find out if my car has a dpf
does my vectra have a dpf
vectra c 1.9 cdti 8v dpf
vectra C 1.9cdti DPF
vauxhall vectra c 1.9 cdti dpf
does my vectra cdti have a dpf
does 07 vectra 1.9 have dpf
does a astra 1.9 cdti have a dpf
