Results 1 to 3 of 3
Thread: Knocking, but disappears when I brake!?
    Nov 2009
    Liverpool, UK
    Default Knocking, but disappears when I brake!?
    Hi,
    I have a slight knocking when driving my v6 CDTI Signum... but diappears even if I only slightly depress the brake pedal!?!
    It seems to be coming from the rear.
    Peter
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Check the brake pads mate..more than likely rattling about.
    WGAF#5
    agreed with dose - you may have lost a retaining clip or spring - worse case scenario you will loose a pad - and could cause the pistons to push into the disc on braking causing you unecessary costs of replacement caliper and pads and discs - get it checked as soon as possible
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. Knocking brake and Snapped spring
    By Thom in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2012, 00:37
  4. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  5. Knocking
    By ianuk in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 23:47
