Thread: clutch/emissions
    manchester
    Default clutch/emissions
    had a clutch fitted today at vx,picked it up alls well 2 hours later emissions light came on,does anyone know if the 2 can be connected many thanks rick
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    probably due to an electrical connection not being put back on properly i had it when i did the service on my old mans corsa spilt a little oil on the lambda sensor plug an light was on in seconds cleaned it and reset the code no problems since
    WGAF#5
    they could have knocked of the cam position sensor - or maybe they havent quite timed up the engine correctly ???
    manchester
    cheers guys,it was some sensor to do with the clutch,he connected it today,hey presto light goes out.thanks again rick
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I am not sure how a cam sensor or timing is affected by a clutch change, aren't they on different ends of the engine?
  1. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  2. egr/emissions
    By squiggy4 in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  3. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
  4. Emissions
    By sb1uk in forum Engine & Drivetrain
    Last Post: 10th April 2009, 12:41
  5. Emissions
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 19:36
