Results 1 to 10 of 14
Thread: Help cleaning EGR valve!
    Regular Member Vectra_Power's Avatar
    York
    Default Help cleaning EGR valve!
    Hi guys, from reading various posts on the site regarding poor performance under 2000 rpm, slightly lumpy idle and poor economy, it appears my EGR needs checking. Here's the question...
    Does anyone that lives in the York area fancy giving me a hand with this? I'm worried about trying it on my own!
    Aug 2009
    sheffield
    hi, its easy,just follow the how 2. if you lived near i would give you a hand ( free ). don,t forget the boost valve how 2
    York
    Cheers mate, I'm going to have a good read and probably give it a go - it does really need it, probably done all it's 119k miles on the original!!
    EVERYWHERE
    Quote Originally Posted by Vectra_Power View Post
    Also check swirl valve operation. EGR valve problems tend to affect the higher rpm performance as well as the lower rpm performance (EGR valve not closing properly, which means that exhaust gas is getting into your engines combustion process when underload and weakening the fuel mixture).
    If your engine is running OK at high revs (no black smoke) I would think that the problem is swirl valves. Swirl valves should close at engine speeds of about just under 2000 rpm. If they do not then they can cause rough running, poor economy, poor driveabilty etc under that engine speed. If the swirl valves remain closed at higher speeds (when they should be open) you will also lose some performance due to them partly restricting the intake manifold. If they are stuck open, performance in the high rpms will not be affected.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If the car smokes alot at lower rpms the swirl valves are stuck open and if there is alot of smoke at higher rpms the swirl valves are stuck shut.
    Gazza4
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    its really easy mate, just watch you dont drop the gaskets when removing the valve
    Regular Member signum03's Avatar
    worthing
    still want to do my y30dt 3.0 v6 cdti but now how to for this engine!
    Jun 2009
    durham
    why do you need to drill the valve and how come it works afterwards?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by sfs View Post
    THe reason for drilling the hole is to knock the solenoid unit out so that the actuator can be sanded to get rid of the corrosion that stops the egr valve working. The hole also serves as a service hole to enable you to grease the egr valve every so often.
    Gazza4
    EVERYWHERE
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Yes, because at low rpms you will not be getting the necessary flow of air mixing with the fuel with the swirl valves open, and if closed at high rpms, you will not be getting the necessary volume of air to mix with the fuel that is being fed into the combustion chamber.
    The thing to remember is that when the car is accelerating or at high rpms the swirl valves should be open and the EGR valve shut. At lower rpms and when decelerating etc, the swirl valves should be closed and the EGR valve will usually be open.
    You say that your car is performing OK at higher rpms, which suggests to me that the EGR valve is closed (as it should be) and the swirl flaps are open (as they should be). But is not performing well at low rpms, which suggests to me that the swirl flaps are remaining open (when they should be closing to help the air enter the combustion chamber more efficiently). Whether or not the EGR valve opens or closes at low engine speeds and not underload does not really affect the performance of the engine. But if it is closing at high rpms, then there's no reason why it shouldn't be closing at low rpms. An EGR valve that remains closed all the time i.e. 'blanked off', will not affect the performance of the car, but will usually bring up a fault light and possibly put the car into limp mode to say that the EGR system isn't functioning correctly.
    Either a faulty EGR valve or a faulty swirl valve can cause black smoke, depending upon whether they are opened or closed when they shouldn't be.
  1. Cleaning EGR Valve?
    By cornishpirate in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2014, 12:48
  2. Help cleaning EGR valve
    By eraser2002 in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 11:54
  3. Cleaning EGR valve ?
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 8th January 2008, 09:33
v6 cdti hesitant acceleration site:www.vectra-c.com
