Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Cdr 2005 vdo help
    Nov 2009
    Willenhall
    confused Cdr 2005 vdo help
    Hi everyone,
    I have recently became a Vauxhall Vectra owner and need some assistance. I will explain my problem.
    I purchased a 04 plate Vectra with and aftermarket CD player fitted.
    I have a CDR 2005 out of another Vectra to put into the car.
    I assumed this would be a simple plug and play as the blue plug fits straight into the CDR 2005.
    I wanted to get the car back to standard so the display would work,
    and I could get the time, date, radio channels to display and also the steering wheel buttons to work as well.
    I removed the aftermarket CD player, then fitted the CDR 2005.
    I assume now the display should now ask me for a code, but I have nothing.
    All there is showing is the out of time and date.
    Is there something I'm doing wrong? or do I have the get a dealer to look at this for me?
    Any assistance with my problem would be greatly apprciated.
    Many thanks
    Lozmark
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I think the screen has to be from the same car. Does it say "safe"
    milton keynes
    Quote Originally Posted by lozmark View Post
    Hi everyone,
    Many thanks
    Lozmark
    power off the stereo and hold down the AS button , power the stereo on whilst holding this and you will hear a beep after about 5 seconds this is where it will tell you to put the code in
    Nov 2009
    Willenhall
    Hi thanks for your reply but I've tried holding the AS button down,
    it does beep but no display on the centre display to put the code in.
    All that is showing on the display is the "out of time and date".
    The guy I had the CDR 2005 said it would just be a plug and play CD player.
    I've since contacted my local VX Dealer and they said the car originally had a
    NCDC 2015 fitted.
    Would this be a problem?
    milton keynes
    yep....wrong GID , it needs to be cdr2005 or ccr2006 GID for you. Which is a shame for you as I just bought one of those gids from diet on here , if you look on ebay they usually go for about £30-40
    Nov 2009
    Willenhall
    Hi and thanks again for your reply, but I'm a bit confused.
    What's a GID? Is this a screen that's compatible with a CDR 2005 CD Player?
    If I buy one off Ebay and fit, will this be all I need or will I need to take it to a VX Dealers to be programmed?
    Lozmark
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    its cause yours will have the later radios that are programed with vauxhall's tech 2 and the old one would need reseting
    Nov 2009
    Willenhall
    Would it be easier just to take it to a VX Dealers to sort or do I need a GID first?
    If I just need a GID can I just fit this without taking it to a VX Dealers.
    Lozmark
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Lozmark
    would go dealer a gid is the graffic info display or the screen should just be a case of finding the correct radio
    Nov 2009
    Willenhall
    Hi are you saying the CDR 2005 I have is no good for my car?
    If so what is the easiest route for me to get the CDR 2005 to fit into my car?
  1. CDR 2005 Aux mod
    By Domchapp in forum Styling
    Last Post: 20th February 2015, 14:19
  2. 2005 2.2 radiator to fit a 2005 1.9 cdti 120bhp
    By IRvectra786 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 08:59
  3. Cdr 2005
    By Das in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2010, 01:44
  4. Cdr 2005
    By penfold2000 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2008, 21:33
vectra c can you fit gid to cdr 2005
will my new cdr2005 plug straiggt in
