Thread: Chain driven engines - oil
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Chain driven engines - oil
    My 1.2 Corsa hasnt even done 3k yet since the last oil change and the oil looks worse than the oil in my missus Vectra which has done 8k since its last change?
    Both cars had GM oil.
    Is it just me or does the oil get dirty quicker in smaller chain driven engines?
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Might depend on what type of driving you do in the Corsa. If its town work only, stop start short journeys then yes the oil will deteriate very quickly. I change my wifes Corsa every 5k cos its only used on short journeys.
    But i also change the Vectra as well every 5k cos i think it makes the engine last longer.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    the quality of oil change cause if you dont drain the oil with the filter housing removed vacume holds around 1/2 a ltr of black old oil inside the motor
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    my lad has a 1.2 y rg corsa-c 91k, and the oil stays fairly clean, ive tried it on fully synthetic this time to see how it goes, have you done a timing chain yourself ??, maybe doing sons shortly + wondered if its a pig or not.
    Oct 2007
    south wales
    Motorway driving mon-fri in the corsa, always change the filter with the oil, as I dont see the point of not doing it, I have changed teh oil twice in the last year since I have had it, s I am suprised.
    Mind you the oil isnt as thin as the veccy oil I use ( 10/40 semi synth in the corsa & 5/30 fully synth in the veccy ), so maybe that has something to do with it.
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Quote Originally Posted by PeterVV View Post
    I don't see any point not using the 5-30 even in the Corsa. The GM 5-30 is a HQ oil, good at removing dirt, and the oil last longer. The 5-30 should fit most of engines on the European market today.
    I would check the breather hose for the valve cover, i.e. If you have a leakage/blockage of "something" in the internal breather system, you might get exhaust into the oil, making the oil dirty very quickly. Its many years since last time I was working on this problem, but as i recall it was a blocked, small airfilter in a breather hose from the valve cover who made the problem.
    My experience is that a black/dark oil does not have to mean the oil is exhausted. What who is important is wether the oil still can make the oil film needed, and clean the engine.
    Bent, my name is Bent
    Mods: I polished it in september...
  1. what vectra c engines are timing chain?
    By broggy in forum Engine & Drivetrain
    Last Post: 6th October 2011, 00:25
  2. Chain driven
    By spooney in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2010, 19:33
  3. Some **** has driven into my car!!!
    By rik_t in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2008, 18:08
  4. Will the new insignia engines be chain driven?
    By sparky71a in forum Insignia car chat
    Last Post: 10th September 2007, 13:42
  5. The best car I've driven
    By ion in forum Non Vectra C/Signum Album
    Last Post: 19th May 2006, 15:47
