Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: first time ever a sump plug has beaten me
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default first time ever a sump plug has beaten me
    drove the car up onto two blocks to give me enough room to change the oil, and couldnt budge the sump plug, I could see the torx head starting to chew it up so had to back off, as I dont have a replacement plug......grrrrrrrr
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Does your sump plug not have a hex around the outside?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    some people worry they will fall out i think so do them up realy tight
    Oct 2007
    south wales
    Nope its a flush round type with a torx socket in it.wish it did! didnt have this problem when I changed the oil before, but since then it went to the stealers to get a stamp, and they must have been having a laugh!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Not much help to you I know but when you go to get a new one see if you can get the one that has a hex on it. Mine has the torx bit in the middle and a hex round the outside
    Jul 2009
    london
    did mine today as well. Sump plug needed T45 bit and a fair bit of oomph to shift it, but it did go eventually. Initially tried to shift it with a small ratchet, but resorted to it's bigger, longer brother to undo.
    Oct 2007
    south wales
    Quote Originally Posted by kabooboo View Post
    Unfortunately I didnt have enough room to resort to hammering in a bigger bit, plus I didnt have a new plug...........grrrrrr, and its pi55ing down!
    Wales
    IFRC only 20Nm for the drain plug on the 1.9 (I am taking a punt on the engine size!)
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Quote Originally Posted by snapsnap View Post
    IFRC only 20Nm for the drain plug on the 1,9
    some first services feals like 200nm
    Jul 2009
    london
    Eek
    Quote Originally Posted by PeterVV View Post
    T45 bit fitted perfect, but just needed to use the bigger ratchet handle to shift it.
    Also didn't help that VX parts initially gave me the wrong oil filter on the first visit - told em it should be a paper element, but the computer decided otherwise.
  1. Sump plug
    By shb1988 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:37
  2. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  3. One sump plug or two on a VVT.
    By disco dan in forum Engine & Drivetrain
    Last Post: 12th October 2011, 18:36
  4. sump plug on my 2.2 sxi
    By smilerwas in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 22:53
  5. Sump Plug Nut
    By si_hoss in forum Engine & Drivetrain
    Last Post: 22nd February 2010, 18:32
vectra c using hex sump plug www.vectra-c.com
vectra cdti sump plug stuck
