Results 1 to 10 of 15
Thread: Front fog light problem
    Sep 2009
    Swindon
    Default Front fog light problem
    Bit of a strange one this. I have a facelift vectra exclusive that has front fog lights in the lower bumper. When I got the car I noticed that there was no switch to turn the front fog's on, only the rear.
    So I presumed that the last owner had a faulty light switch and replaced it with the wrong one, I ordered a new switch with buttons for both front and rear fog's but the front switch doesn't do anything. All the wires seem to be there for the front fogs on the bumper.
    Any one have an idea what's is going on here?
    Frenchman
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    what model of vectra have you got?
    Sep 2009
    Swindon
    Hi,
    It's a 2006 exclusiv estate.
    Frenchman
    Jan 2008
    Dundee
    not all of them had front fogs as std. check they relays and fuses mate. it does sound odd.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Possibly retrofitted by a previous owner, they might need tech2 to activate them
    Jan 2008
    Dundee
    was thinking that but then again there are exclusives out there with them
    Sep 2009
    Swindon
    Well it is a bit strange that the wires are there and connected to the fog's, yet the switch had no function to turn them on.
    The car has had a bit of a knock at the front at some point in it's life, so it is possible the bumper is not original. I just checked on the parkers web site and it tells me that the front fog's were standard on the design and not the exclusive.
    So strange thing is the wiring must have been there all the time, but the switch is different. You could be right about the tech2 to activate then which is a pain.
    Frenchman
    Sep 2009
    Swindon
    Will also get the haynes manual out and check for fuse also
    Jan 2008
    Dundee
    you'll find that the loom in most cars is the same. mine is an sri and has loom for headlamp washers which were only on gsi's. but in order to get them to work. the car needs to be tech2'd
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Don't want to upset you, but if the fogs aren't an original fit, then it is unlikely that they will be a simple tech 2 in job.
    I retro fitted front fog lights to the loom plugs and fitted a new switch panel with the front fog switch...and nothing. (switch was approx £45 from Vx)
    Went to Vauxhall to Tech 2 in, and they said that the circuit was incomplete and so could not be done.
    I ended up doing my own via a relay controlled by the cigar lighter illumination wire, and then onto a separate switch...
    this way it functioned as it should...
    only when the side lights / headlights are switched on.
    My Car is an Energy....sort of part club / exclusive and part LS / Design.
  1. Rear Signum Light problem problem - help
  2. TC light problem
    By fester999 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 18:45
  3. Rear Interior Light Fitted - Problem with front now....
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2009, 00:08
  4. front indicator light problem
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2009, 10:58
  5. Problem - ABS light is on!!
    By pamsie36 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2008, 18:16
I fitted front fog lampe to a vectra c but dont work
